brake caliper testing
Old Oct 31, 2010 | 06:30 PM
red deuce's Avatar
red deuce
Default brake caliper testing
Is there a way to test a rear brake caliper short of installing it on my bike? If so do you think the stealer will have that equipment? thanks
Old Oct 31, 2010 | 06:40 PM
RocketRocker's Avatar
RocketRocker
I have not heard of the stealer having such test equipment but not much time to just hook it up and see if its operational
Old Oct 31, 2010 | 06:49 PM
0734's Avatar
0734
You can test it "off the bike" but it will have to be connected and bled. Stick a thin section of wood, like a piece of flooring, paneling or 1/4-inch plate in between the pistons....bleed the brakes and see how the pedal feels.
Old Oct 31, 2010 | 07:05 PM
Jackie Paper's Avatar
Jackie Paper
Default Test
You could do it with air if you are careful but what would it show. However this is what I do on the 4 piston ones on my bike which I think works well for me. First when changing pads I do not push them in. I simply pull the caliper and then pull the pads. I place a slightly thiner piece of plyboard in their place and push the pistons out slightly more. Then I carefully clean the exposed area. Then I reinsert the board and a scraper and lever the pistons back in as far as they go. Then I carefully press the master cylinder watching that all 4 pistons move equally. It would be no big deal to check it if it has banjo fittings using the bikes line and a box to lay it on. When I pull mine I lay it there. Doubt if dealer goes to this trouble.
Cullmanco
Dec 17, 2018 06:16 AM
Sidius
Jul 11, 2016 12:59 PM
that$pit
Feb 9, 2015 01:19 PM
Krazy8s
May 15, 2014 11:20 AM
KiloGolf4
Aug 24, 2012 07:58 PM
