Softail wheel bearings interchange
Old Nov 7, 2010 | 06:25 AM
chilock's Avatar
chilock
Default Softail wheel bearings interchange
Have an 08 FLSTC with the laced profiled rims. I am looking for a new front rim which is 16x300D. I know that 07 up uses a 1" inside diameter bearings and axle. Before that was 3/4".
If I buy a 06 rim do I just change the 3/4'' bearings to 1'' and reuse my stock 1" axle?
Could it be that simple or am I missing something? Would the OD of the bearings be the same?
Also from what I read the 08 rim should be 16x3.5. Mine is 16x3.0. I know it went in service in april 08. Did the rim size change
Thanks for any information.
Old Nov 7, 2010 | 06:58 AM
jsbridgew's Avatar
jsbridgew
you have to lace up your 08 hub (1 inch) to the wider 16 inch rim from the 06
Old Nov 7, 2010 | 07:01 AM
soft 02's Avatar
soft 02
Yup. and have fun lacing your rim. Everyone should do that themselves at least once.
Old Nov 7, 2010 | 07:03 AM
chilock's Avatar
chilock
not me.
So the 06 earlier had the 3.5 rims and the 07 newer have the 3.0?
same hub size though and bearing would interchange. Obviously I wont go that route but just curious
Thanks
Old Nov 7, 2010 | 07:05 AM
chilock's Avatar
chilock
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
so these wont work ?
Old Nov 7, 2010 | 07:38 AM
jsbridgew's Avatar
jsbridgew
where did you read that the stock front rim on an 08 was 3.5?
as far as i know it's 3.0...only different between 06 and 08 would be hub size
roussfam
Jul 27, 2014 09:10 AM
Miguelpoire@yahoo.com
Feb 3, 2012 03:32 AM
blair
Sep 3, 2010 12:30 AM
soft 02
Jul 29, 2010 09:48 PM
BigSeaDaddy
Nov 1, 2009 08:10 AM
