true dual burns
Old Nov 13, 2010 | 03:39 PM
BLKnCHRME09Deluxe's Avatar
BLKnCHRME09Deluxe
Originally Posted by OldBoldPilot
You might stop taking off your pants
+1 on that note...lol... #1 rule with true duals... always wear pants while riding your bike!
Old Nov 14, 2010 | 10:22 AM
tk353's Avatar
tk353
what he said
Old Nov 16, 2010 | 03:38 PM
CustomRKC04's Avatar
CustomRKC04
I have ceramic coated exhaust on my bike and it took off 500 deg. from my pipes. So I would recommend sending your pipes out and getting them ceramic coated.
Old Nov 16, 2010 | 03:44 PM
07Fatty's Avatar
07Fatty
What did that cost CustomRKC04?
Old Nov 16, 2010 | 04:16 PM
oct1949's Avatar
oct1949
After I did the stg1 and later did the cams,, both of them together took the oil temp from 245 to 215... and it has to make the pipes cooler along with it...
so do like most of us have,, do a f/m system and add some cams then do a dyno tune and she'll run cooler...
Old Nov 16, 2010 | 04:22 PM
Iceman24's Avatar
Iceman24
Little different set-up, but I had my 09 FLHX exhaust ceramic coated for $160 (header, pipes & shields). Not that spendy at all & really does make a difference w/heat.
Old Nov 16, 2010 | 09:38 PM
tk353's Avatar
tk353
ceramic has many other advantages like it wont turn colors and it also spreads the heat the entire pipe so there are no hotspots and it helps cool the exhaust too. helps the engine run more constant. i found the next set i am going to get.
http://www.denniskirk.com/jsp/produc...fCatId=&mmyId=
Old Nov 17, 2010 | 11:17 AM
CustomRKC04
it was about 175 but it was well worth it.
Old Nov 17, 2010 | 12:04 PM
2006FLST's Avatar
2006FLST
Beat me to it Do what Drew said. It should not be getting that hot to turn the heat sheilds. Case in point I ran my pipes with no wrap or sheilds for while before wrapping them. Heat was never a big problem. And I am a short sh*t so my legs were close to the pipes.
Old Nov 18, 2010 | 02:34 PM
Daraamanthas's Avatar
Daraamanthas
Thank you all. I will try all of the above except the pants, I just feel more liberated that way) Besides it keeps the ugly old farts from staring......
