Project "Clean Bars"
Old Nov 24, 2010 | 12:18 AM
bmr's Avatar
bmr
I'm looking forward to see the results on this, keep us posted.
Old Nov 24, 2010 | 05:08 AM
pococj's Avatar
pococj
Originally Posted by Fireman1501
What cable did you use? Brand? And when you cut the cable how did you keep it from fraying? I am going to need a 60" to 62" cable on mine.
Used a Barnett with the S&S carb end as I have an S&S E carb. I used a tubing cutter to cut the outer jacket. I cut the inner cable with a pair of high quality electrical side-cutters. In the past I've used a propane torch to heat the end and flowed some solder into the strands. It can be a PITA because often the strands don't want to accept the solder. This last time I didn't do anything with the strands, but just made sure to handle them with care until I got the throttle assembled.
Old Nov 24, 2010 | 07:18 AM
Fireman1501's Avatar
Fireman1501
I was told to use the throttle grip end on the carb side so you can have the adjustment exposed and not in the bars. Both cable ends look to be the same size on my cv carb and handle grips. Guess it will make more sense when the internal throttle arrives.
Old Nov 24, 2010 | 08:28 AM
WARG's Avatar
WARG
Adding heat shrink to the entire length is a good idea. I did that when I wired my 16s. A little extra peace of mind.
Old Nov 24, 2010 | 10:10 PM
pococj's Avatar
pococj
yeah, it'll be pretty obvious when you see the throttle. I thought I used my cable as designed - carb end at carb - and the adjuster is under the tank, but closer to the carb. Now I'm wondering if it is actually as you say. Oh well, it works!
Old Nov 28, 2010 | 12:35 PM
Fireman1501
Ok was finally able to get some time in to work on the bars. But seems that the companies in FL have the slowest shipping ever know to man. Ordered bars from Carlini last thursday and also ordered the internal throttle from Streamline, and grips from Thunder Cycles on Thursday also. And bars arrive Tuesday and the throttle and grips are still not here. But was able to get wiring and brake line ran into the bars. Note to anyone doing this when you drill the hole for the brake line the Carlini bars have a thick wall bar and also have an internal bar that I found. At which made my day. It was a pain in the ars to drill through both bars to get the line to fit into the bars, but got it done. Here is the pictures.
Till next time, which hope us this week.
Old Nov 28, 2010 | 01:15 PM
WARG's Avatar
WARG
Loving that...nice and clean.
Old Nov 28, 2010 | 01:18 PM
Brad2064's Avatar
Brad2064
Do you think this could all be done on 1.25" bars? Or are the 1.50" bars necessary to run everything internal? Could you run normal throttle cables into the bars like you did the brake line, or do you have to get an internal throttle system?
Old Nov 28, 2010 | 01:19 PM
Kowan's Avatar
Kowan
Oh man, great looking job so far.
Old Nov 28, 2010 | 01:23 PM
Fireman1501
The system I am using only uses one throttle cable. So I think that drilling the bars for the external throttle cables might be to much. I would just go get the bar clamps and have them lined up next to the bars. A person can do this on the 1 1/4" bars also. It all comes down to making everything nice and tight. The brake line hole is only a 1/4" so it is really not that big at all.
