cv carb float getting stuck
Old Nov 30, 2010 | 08:56 PM
yank's Avatar
yank
Default cv carb float getting stuck
how do rebuild my carberator? the float keeps getting stuck and i have already cleaned the bowl a couple of times.
Old Nov 30, 2010 | 11:49 PM
oct1949's Avatar
oct1949
Heres one I found on how to tune her.
http://www.harley-performance.com/ha...arburetor.html
Heres the same problem other members has had..
https://www.hdforums.com/forum/engine...wont-idle.html
Hope something in here Help Ya....OCT1949
__________________
Old Dec 1, 2010 | 05:40 AM
Doug S's Avatar
Doug S
Is the float sticking open or closed, probably open and the gas is overflowing. Either way, if the bike runs well otherwise, you only need to replace the float needle valve. It's right under the metal flange on the float, take float off, replace needle ($15.00) and slap it back together. If you have not bent anything then there will probably be no adjustments needed.
D
Old Dec 1, 2010 | 06:00 AM
Dixie Dreg's Avatar
Dixie Dreg
Also you have to make sure that the float is sitting at the correct angle, if it is not then you can adjust it, it is covered in the manual.
jdl2430
Carburetor Related
May 13, 2015 09:44 PM
randybecker
Sep 14, 2011 11:29 PM
jaredb
EVO
20
Apr 4, 2011 08:07 PM
edjhover
EVO
11
Aug 21, 2010 08:44 PM
trozenhorse
Jul 21, 2010 12:00 PM
