Stupid question
Old Dec 5, 2010 | 06:26 PM
ramhunter9's Avatar
ramhunter9
Default Stupid question
04 FXST
Can I run Lucas 20w-50 full synthetic in the engine , primary, and trans .
I want to keep it all the same if i can .
Also double check me if you will .. is this correct ...
3.5 quarts for engine and filter
24 oz for trans
and primary I haven't found that yet , so if you know the amount I would greatly appreciate it .
Old Dec 5, 2010 | 06:43 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Primary is 24-26 oz I believe. The engine will only need three quarts at the very max as 3.5 is for a dry engine. I always add two quarts to the engine, let it run for a minute, check the level and go from there.
Drew
Old Dec 5, 2010 | 06:49 PM
ramhunter9's Avatar
ramhunter9
Thanks Drew . As for the trans am i correct in that its 24 also . Im still learning the Harley . Im pretty mechanically inclined , just want to get my ducks in a row .
24 oz for trans ????
24-26 primary
Also IS it ok to run lucas 20w-50 in ALL of these ?
Old Dec 5, 2010 | 07:08 PM
ramhunter9's Avatar
ramhunter9
Anyone ? Need to punch this oil order but what to be sure
Old Dec 5, 2010 | 07:17 PM
Captain Itch's Avatar
Captain Itch
Sponsor
20-50 ok for the engine
Tranny 85-140 gear oil
Primary up to you but do not use motor oil..it has additives and your clutch will slip..
__________________
www.Captain-Itch.com
Old Dec 5, 2010 | 07:22 PM
Faast Ed's Avatar
Faast Ed
Why? . .
Old Dec 5, 2010 | 07:34 PM
ramhunter9's Avatar
ramhunter9
Just so I dont have to buy 3 different oils
Old Dec 5, 2010 | 07:38 PM
ramhunter9's Avatar
ramhunter9
so is it 24 oz for the trans ?
and 24-26 oz for the primary ?
Lucas seems to be the one I want to try for the oil . and i know its 3 quarts . The other I need to find out how much and what would be recommended .
Old Dec 6, 2010 | 05:38 PM
Deuce_of_Spades's Avatar
Deuce_of_Spades
I run Amsoil 20w-50 in all three holes. I ride pretty hard and have been very happy with Amsoil!
superglide03
May 1, 2015 07:00 PM
BLACKFLST
EVO
Aug 21, 2014 05:00 PM
harleyglen
Sep 29, 2013 09:21 PM
Cmonks91
May 8, 2013 08:32 PM
jimmyroadking
Oil Archive (no new posts)
Jan 13, 2010 08:36 PM
