Cross Bones Riser Question
Old Dec 6, 2010 | 06:56 PM
Budmiester's Avatar
Budmiester
Default Cross Bones Riser Question
I swapped out handlebars to a set of Wild Ones Chubby 16" Black Apes. The stock risers seem to be too soft of a metal to keep the bars from moving. The knurling on the Wild Ones Ape is real aggresive and with the added leverage of the taller bars, it just chews up the stock risers. I've tried a variety of fixes, with no luck. This includes drilling through the riser caps and bars, riveting a riv-nut inside the bars and tightening it all up with a screw. This was all done with aviation grade hardware. Can anyone recommend a good set of after-market with strong enough metal to hold the bars tight?
Old Dec 6, 2010 | 07:11 PM
brettnbama's Avatar
brettnbama
I got a set of Alloy Art goodentite riser bushings. There is a specific P/N for the Crossbones. Alloy Art P/N GT_CBS http://www.denniskirk.com/jsp/produc...uctId=pH210768
I bet Drew can hook you up. I only linked this to show it to you.
My bars (not in sig pic) are Wild 1's 14" Outlawz, there is 0 play in my bars. Another thing you may want to look at is putting "grip tape" on the inside of your risers, or getting a grinder and getting rid of what is left of the powdercoat.
Old May 11, 2011 | 01:13 PM
sampson1967's Avatar
sampson1967
Stage II
Default Did you resolve this problem?
I have the same bike, bars (16 chubby ) and problem! Did you ever fix this? help!
Old May 11, 2011 | 01:37 PM
brettnbama's Avatar
brettnbama
there have been a few crossbones owners that have had these issues, I (knock on wood) have not had any slippage yet. One thing you can do is pin your risers. This involves driling a small hole in the riser, putting in a roll pin, then drilling a hole in the bars to hold them in place.
Old May 11, 2011 | 03:54 PM
Nicky Pass's Avatar
Nicky Pass
Buy another rise top clamp and drill two holes in the top and put some set screws in....you can use Harley license plate screws with the HD log or the Willie G. Skull.
Old May 12, 2011 | 08:34 PM
Mars1's Avatar
Mars1
I have an 09 with the same set of bars, did you change out the bushings when you installed the bars? Reason I am asking is I left the rubber bushings in, the bars flex a little but have not had any slipping....Yet..
Old Jun 26, 2011 | 11:52 AM
ShortFatMexican's Avatar
ShortFatMexican
Question bars slipping...
Just wondering, what happened when you drilled through the caps and bars? Did this fix not work or were you just looking for something better? I have an '09 FXDB with the same problem, except for some reason my 14" Burly's came with no knurling and my clamps don't either. I've limited out my torque specs and still, everytime I hit a big bump in a road somewhere, my bars pull back a few inches. Anyone else have any ideas?
Old Jun 26, 2011 | 01:37 PM
Budmiester's Avatar
Budmiester
All of the fixes I've tried haven't helped much at all. I've also drilled out the threaded portion of the risers and put in Heli-Coils so I could get more torque on the fasteners. Drilling through the riser caps and bars, with a riv-nut inside the bars, didn't cure the problem they way I wanted to. I want to get it to where the bars don't slip at all. I have a friend who is a machinist. He's going to fab a set of risers out of 7075 billet aluminum. When I did the original swap I changed the riser bushings to poly. Has nothing to do with the slippage, but they do seem to work better at dampening than the stock rubber baby buggy bumpers.
Old Jun 26, 2011 | 05:59 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
When your buddy machines the risers have him put a few threaded holes with set screws to hold the bars in place. My Carlini risers came with these and they have always been rock freaking solid.
Drew
Old Jun 26, 2011 | 08:42 PM
Budmiester's Avatar
Budmiester
I started off drilling and tapping the stock risers with a set screw. Still had slippage. Next project, put riv-nuts in. Those are nut plates that I fished up the inside of the bars, rivet in place with flush mounted Cherry Max rivets. So when I put the whole thing together, the screw goes through the riser cap, then the bars, then threads into the nut in the bars. Tighten it up and problem solved, right? Not quite. If this next project doesn't work, Ill just weld them in place!
