Hi Drew, just ordered a set of these: Wide Flanders 1-1/4" Apehanger Bars :Measurements Height:13" Pullback: 10.5" Center: 11" Width: 36.5" Diameter: 1-1/4" These Bars are 1-1/4" across the center and require the use of 1-1/4" diameter Riser Clamps
I've got the risers coming and they are 1.5" tall, I'm gonna need wire extensions and both throttle cables and a front brake line for an '03 FLSTCI. Think you can hook me up without me doing any measuring? I'd like shiny,coated, stainless with the teflon or whatever for the cables to slide on inside if you have access to that kind of stuff. I thought about PMing this, then figured someone else might benefit from any info you offer.
Thanx
