Hello, I have searched on here, and found some information confusing. Do you have to drain the transmission fluid before you change the transmission cover?
I have read that you can keep the bike straight up on a lift and you do not have to. Can anyone please shed light on this? I also want to change the cam cover, too. I do not have a service manual, although it is ordered.
Thanks.
If you leave your bike on the side stand you will only lose a few drops of oil out of the transmission. No need to drain it completely. the same goes for the cam cover.
