Cam Cover Replacement
Old Jan 11, 2016 | 05:12 PM
Berick's Avatar
Berick
Default Cam Cover Replacement
I am going to be changing my cam cover over...... do I need to drain the engine oil to do this or can I just sit the bike over on the jiffy stand?
Old Jan 11, 2016 | 05:43 PM
joe40x's Avatar
joe40x
Jiffy stand. You'll get 3-4oz out of the cam cover if that much.
Old Jan 11, 2016 | 05:48 PM
QC's Avatar
QC
Get a "Pig Form-a-Funnel to help keep your frame clean.
https://www.google.com/url?sa=t&rct=...11396085,d.cGc
Old Jan 11, 2016 | 05:56 PM
gusotto's Avatar
gusotto
You won't get much to drain out but I'd have a pan under the cam cover.
It'll be primary oil, not engine oil.
Old Jan 11, 2016 | 06:05 PM
Berick's Avatar
Berick
Does a guy have to worry about topping up the oil if I lose 2-3 ounces while changing the cover?
Old Jan 12, 2016 | 05:10 AM
joe40x's Avatar
joe40x
It'll be primary oil, not engine oil.[/QUOT
Primary oil in the cam chest? No it's engine oil.
Old Jan 12, 2016 | 03:29 PM
dfwhockey17's Avatar
dfwhockey17
What?!?!?!?!
Since when does your primary oil run through the cam chest?
Old Jan 12, 2016 | 08:03 PM
Sgt_Jim's Avatar
Sgt_Jim
Yeah, it's engine oil.. and it's best to keep it on the kickstand and keep it leaning to the left. You'll get the least amount of oil out that way.
Old Jan 12, 2016 | 10:32 PM
JeffJA's Avatar
JeffJA
Originally Posted by dfwhockey17
What?!?!?!?!
and i thought i was reading that wrong!...
Old Jan 14, 2016 | 11:25 AM
Joe_G's Avatar
Joe_G
I did a how to thread on checking your cam tensioners which requires removing the cam cover. It's an easy job with a long ball end allen from Harbor Freight and a Pig funnel. Hardest thing is getting the cam cover off once the bolts are all loose (leave one in to hold it). I used a thin screwdriver to carefully get it started. I was able to reuse the steel coated gasket and no leaks.
Here's more with pictures:
https://www.hdforums.com/forum/softa...with-pics.html
HDmikie
May 3, 2012 09:23 PM
Mrkolivers
Nov 20, 2011 01:38 AM
bigsofty
May 14, 2010 10:11 AM
07RoadHawg
Jan 26, 2009 07:05 PM
JORENO
Oil Archive (no new posts)
Aug 29, 2008 12:24 AM
