Checking Cam Chain Tensioners.....
Old May 1, 2012 | 04:32 PM
HDmikie's Avatar
HDmikie
Default Checking Cam Chain Tensioners.....
Just curious if it's a good idea to drain the oil before pulling off the cam cover. Anybody pulled the cover off without draining oil? Thanks!
Old May 1, 2012 | 04:56 PM
HammerheadC4's Avatar
HammerheadC4
I checked mine a couple times, I didn't drain the oil.
Bike was leaning on the kickstand when I removed the cam chest cover.
Old May 1, 2012 | 07:46 PM
HDmikie's Avatar
HDmikie
Thanks for the reply. This is good to know. I wasn't sure if oil would run out after pulling off the cover.
Old May 1, 2012 | 09:24 PM
sddyna's Avatar
sddyna
You will lose a little but just have a drain pan or rag to catch it. It will not amount to enough to worry about though. Good luck with the inspection!
Old May 1, 2012 | 10:29 PM
dickey's Avatar
dickey
Draining the oil from the tank will not affect the oil level in the engine sump, unless you drain the engine sump itself, & trust me--you DO NOT wanna mess with that drain plug. Imprecise installation of that plug can crack your cases.
Old May 2, 2012 | 05:52 AM
HDmikie's Avatar
HDmikie
Thanks again guys. Hey Dickie, I never heard how your special date went a few weeks ago. Last time I checked there was about 10 pages of posts waiting to hear about the date.........so how was it?
Old May 3, 2012 | 09:23 PM
HDmikie's Avatar
HDmikie
Follow up: after 14000 miles both tensioners looked about 90 percent so I think wait another 20000 miles before checking again. Thanks again!
UT-rckr
Aug 28, 2015 06:15 AM
Mikeduke108
Jun 28, 2014 04:08 PM
NYCFXDC13
Jun 1, 2013 03:38 PM
07RoadHawg
Jan 26, 2009 07:05 PM
astro929
Jul 9, 2006 08:25 PM
