Need someProgressive 422 pics
Old Jan 7, 2011 | 03:10 PM
kozy22's Avatar
kozy22
Default Need someProgressive 422 pics
Anyone have pics with the Progressive 422's (Lowered and higher). I think thats they way I'm heading
1. How easy is it to adjust the height. Can it be done without a jack
2. It says 2" under stock, so would that be only 1" under stock on a deluxe
Old Jan 7, 2011 | 06:01 PM
Ash16's Avatar
Ash16
I have them. The ride is good. I don't know about the height adjustment. I put them on lowered almost all the way and never changed them. The pre-load is easy to adjust and I didn't lift to do that.
Old Jan 7, 2011 | 08:18 PM
Malingerer's Avatar
Malingerer
These are the 422 at the lowest setting.Actually a little beyond the lowest setting.It really needs to be raised up a little.Setting the preload is easy and does not need to be jacked up.The height adjustment is easy as well but it is a little more work.It is much easier to adjust the height when the bike is on a jack.It takes a lot of the weight off the shocks.Makes it easier to loosen the nuts that rest against the bushing cups.
Attached Thumbnails Need someProgressive 422 pics-dsc01551.jpg   Need someProgressive 422 pics-dsc01543.jpg   Need someProgressive 422 pics-dsc01547.jpg   Need someProgressive 422 pics-dsc01546.jpg
Old Jan 8, 2011 | 10:49 PM
kozy22's Avatar
kozy22
Thanks, your bike looks sick. Almost makes me wish I went with that color scheme.
Anyone else have some pics or comments
Old Jan 9, 2011 | 12:24 AM
Cari Rohs's Avatar
Cari Rohs
Stage II
Can an 2009 rocker c use the progressive lowering kit safely?
Old Jan 9, 2011 | 12:30 AM
Cari Rohs's Avatar
Cari Rohs
Stage II
Has anyone lowered a 2009 rocker c using the lowering kit bolts? Once lowering is done will kickstand need to be changed? Has anyone lowered this bike with any other method?
Old Jan 9, 2011 | 01:29 AM
97FXSTSB's Avatar
97FXSTSB
422s on mine. Sig pic shows it lowered all the way.
Old Jan 9, 2011 | 02:03 PM
Progressive Suspension's Avatar
Former Sponsor
Malingerer, Great looking bike!
kozy22, sounds like you're getting the answers you needed, hit us up if there's anything else we can help with.
Old Jan 9, 2011 | 02:43 PM
Malingerer's Avatar
Malingerer
Thanks.
Old Jan 9, 2011 | 02:44 PM
Malingerer's Avatar
Malingerer
Thank You
