07 FXST Main Shaft Nut Trouble ...Need Suggestions.
Old Jan 23, 2011 | 10:13 PM
junkdk's Avatar
junkdk
Unhappy 07 FXST Main Shaft Nut Trouble ...Need Suggestions.
Hey,
So I am trying to install a new 30 tooth pulley and I can't get the damn nut off the mainshaft.
I have tried leverage, which broke my first breaker bar, then heat, then some kroil, and finally a impact wrench at up to 500 torque(which is starting to wear the socket tool). That bitch won't budge!
I have the service manual which says its right hand thread plus it also says it on the pulley.
I need some suggestions.
I am at the point of getting a propane torch or cutting it off.
Help,
dk
Old Jan 24, 2011 | 07:14 AM
RHillbilly's Avatar
RHillbilly
did you remove the lock,sometimes you tighten it a little then back it off helps when they are loctited
Old Jan 24, 2011 | 07:37 AM
hspring03's Avatar
hspring03
reverse thread, electric impact gun.
Old Jan 24, 2011 | 07:38 AM
dan conner's Avatar
dan conner
main shaft and nut trouble? sounds like a job for viagra!!
scruf
Nov 28, 2017 02:29 PM
scottdoege
Aug 6, 2016 11:36 AM
Hog Yild
Feb 5, 2010 11:19 AM
Rangerbob
Aug 6, 2009 10:21 AM
Pidgin
Apr 21, 2008 01:38 PM
