question on true duals
Old Jan 31, 2011 | 10:42 AM
whit42's Avatar
whit42
Default question on true duals
Sorry if this sounds like a dumb question, I am currently running Rush 2.0 slipons on my 09 Heritage. I would like to go to true duals as I love the balanced look of a pipe under each bag, plus the improvement in tone. Is it possible to use Rush mufflers to do this, and if so, can I use the slipons I already have? I would probably switch to 1.75 baffels, to tone it down just a little. I'm running a SERT so I realize it would have to be re-tuned.
Thanks for the help, this is a great forum!!
Old Jan 31, 2011 | 11:07 AM
shineybike's Avatar
shineybike
I don't believe you can use the rush mufflers you have since the mounts are different. If you check around on here or on ebay for springer mufflers you should be able to get a photo showing the way the mufflers mount. They are essentially mirror images of each other. The actual mounting of whatever mufflers you get will depend on what true dual head pipes you get, unless you get a complete system from one vendor.
Old Jan 31, 2011 | 12:52 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
You need to figure out what brand of true duals you want to use and call the company and ask them. As far as the mounting I don't know...It is more expensive to get the full system, but it will all line up and bolt right on. Priceless in my book. I like the Samson true duals myself.
Drew
Rush Racing Products's Avatar
shineybike is correct.
Old Jan 31, 2011 | 03:51 PM
DeluxeW00kie's Avatar
DeluxeW00kie
*cough* Cholos *cough* :-)
Old Jan 31, 2011 | 08:14 PM
whit42's Avatar
whit42
Thanks for the info gents, I appreciate the help and tips. Need to think this through a little farther.
Old Feb 1, 2011 | 08:22 AM
shineybike's Avatar
shineybike
I re-read your original post. Although you can't use the rush mufflers you have now, you can use rush mufflers for true duals. This might get a little wordy but....I had a stock 2002 heritage springer dual exhaust on my bike. I put on samson true dual headers and rush staight cut mufflers for true duals. The muffler mounts did not match up with the stock springer muffler mounts so I got a length of flat bar and drilled holes in the right places so I could mount the mufflers on the stock mounts. I found that option easier than using the samson muffler mounts which I had. So, in answer to your question you can use rush mufflers, just might have to fab something like I did. Rush sells a true dual head pipe setup but I was going on a budget and found the samson head pipes used and a deal on the rush mufflers too.
Old Feb 3, 2011 | 07:53 PM
NoDeal's Avatar
NoDeal
Like said above, need to get matching brand exhaust to the true dual headpipes. Personal favorite are the Vance & Hines softail duals.
Old Feb 3, 2011 | 11:02 PM
oct1949's Avatar
oct1949
Its all about the mounting brackets....
call rush---- http://www.epiflex.com/
vtHDrider
2014-2024 Touring Models
13
Apr 29, 2018 07:15 PM
tlar1540
May 15, 2012 07:28 PM
pt4u2nv
May 23, 2011 07:22 AM
LTDDD
Exhaust System Topics
Nov 2, 2007 07:36 AM
HilllBillly
Jun 19, 2007 01:28 PM
