Softail Standard Guys- Rear Fender Conversion
Old Feb 6, 2011 | 11:22 AM
Jagzz4's Avatar
Jagzz4
1st Gear
Default Softail Standard Guys- Rear Fender Conversion
For those of you Softail Standard guys that have switched over the rear fender from Bob Tail to the other down turn fenders:
Did you use a fatboy fender of the same year model? If so, does this just bolt right on? Do you have to do any other mods to tail light.. etc.?
I have an 05 Softail Standard.
Please post pics if you have done this. RamHunter, like your bike a lot. Please share if possible.
Thanks!
Old Feb 6, 2011 | 12:27 PM
story808's Avatar
story808
Yes if you get the same year it will just bolt right up... But you can find other years that will bolt up to like deluxe fenders since they don't have the 200 like the new fatboys. I used a 06 deluxe for my 05 NT.
If you just buy the fender will need to find a tailight and on the inside of the fender you have support bracket "FXST" if you use yours you will need to cut it to fit in the long fender... but it's real easy.
Old Feb 6, 2011 | 02:48 PM
Big H's Avatar
Big H
One of the Softail fenders would be a direct fit but you could also get a shorter aftermarket fender that is the correct width. It would require drilling the correct holes for the strut mounts but would look a bit more hot rod with the skinny front end your bike has.
Old Feb 6, 2011 | 06:11 PM
bikerlaw's Avatar
bikerlaw
Damn, thats a good looking motorcycle.
Originally Posted by story808
Old Feb 6, 2011 | 06:18 PM
richmac64's Avatar
richmac64
Since you have an '05 you will have alot more options and they should bolt right up. I have an '06 with the 200mm tire so I used an '07 Fatboy fender and bolted it right on.
Skeezmachine
Apr 10, 2014 09:43 PM
mphillips
Sep 26, 2010 09:59 AM
medina charlie
Dec 10, 2009 10:25 PM
SC-Longhair
Apr 13, 2009 08:59 AM
chrome-dome-dave
Oct 20, 2008 10:21 AM
