Engine Pop question
Old Feb 20, 2011 | 08:20 PM
Rocker_UAE's Avatar
Rocker_UAE
Default Engine Pop question
Im planning to do some engine work and have been reading alot lately on the different options but the current setup im running causes a loud pop between shifts when going flat out.
Im running the vance and hines air cleaner and vance and hines big radius 2 into 1 with no tune so far.
When running against a rocker with the same set up but with a powercommander i left him in my dust. There was no comparison which is strange because the tune should improve the performance as far as i know.
What are your thoughts/suggestions on this? im thinking of replacing the vance and hines cleaner to the screaming eagle heavy breather and power commander and having it dynod.
Also, how bad is the pop for the engine because it turns alot of heads
Thanks
Old Feb 20, 2011 | 08:38 PM
oct1949's Avatar
oct1949
A/F ratio and or an air leak in the pipes can cause the popping..
Old Feb 20, 2011 | 09:05 PM
cpiad's Avatar
cpiad
Account Closed
Plus one on oct1949....
But...given your mods...and u r using factory ECM....more than likely cause is "afterfire" which happens in the exhaust and not "backfire" which happens on the intake side. Afterfire pop is annoying....but not damaging. Backfire will blow up an intake.
I bet this started when you took off the factory pipes...now you no longer have a cat and some sunburned mixture is getting ignited when flame blows past a closing exhaust valve. Also...happens more when engine is lean....high AFR...and when timing is advanced a bit too far. No doubt you are lean...factory ECM runs lean....and a stage 1 setup makes it even leaner....I suspect u may also have predetonation...which is bad thing. Some "turners" aka aftermarket ECMs...allow you to cut fuel supply while acceleration from when it starts (high rpm point) to when it quits (low rpm point). I have a zippers Thundermax with that capability...but I am certain other units do also.
I used to street race cars in my younger dumber years...sometimes less powerful cars are left in the dust ....even in a drag race...by the better...bolder driver....lots of the time.
Old Feb 20, 2011 | 09:12 PM
cpiad's Avatar
cpiad
Account Closed
Please disregard my earlier post...this damn phone makes incorrect corrections....and mobile HD forum won't allow editing.
Given your mods...and u r using factory ECM....more than likely cause is "afterfire" which happens in the exhaust and not "backfire" which happens on the intake side. Afterfire pop is annoying....but not damaging. Backfire will blow up an intake.
I bet this started when you took off the factory pipes...now you no longer have a cat and some unburned mixture is getting ignited when flame blows past a closing exhaust valve. Also...happens more when engine is lean....high AFR...and when timing is advanced a bit too far. No doubt you are lean...factory ECM runs lean....and a stage 1 setup makes it even leaner....I suspect u may also have predetonation...which is bad thing. Some "turners" aka aftermarket ECMs...allow you to cut fuel supply while de-acceleration from when it starts (high rpm point) to when it quits (low rpm point). I have a zippers Thundermax with that capability...but I am certain other units do also.
Old Feb 20, 2011 | 09:31 PM
HoggyMtnBreakdown's Avatar
HoggyMtnBreakdown
+1. Better mods or build cannot compensate for a lack of drag racing "skills".
Old Feb 20, 2011 | 10:04 PM
cpiad's Avatar
cpiad
Account Closed
Indeed brother...I learned that fact on some straight flat roads in Virginia many decades ago....
Capt Steve
Oct 6, 2017 03:00 PM
eric.west
The Dyno Room
Nov 22, 2016 12:42 PM
The Cheesehead
Mar 5, 2016 06:22 AM
postal_cz
Apr 12, 2013 12:02 PM
matts Dyna
Apr 21, 2010 01:30 PM
