Seat Removal - Damn Bolts
Old Oct 10, 2006 | 07:48 PM
Dunk 2's Avatar
Dunk 2
Default Seat Removal - Damn Bolts
I need to get to the battery on my '07 Softail Deluxe. What kind of tool do I need to take the seat bolts off? I thought that an allen wrench would work, but I guess that would be too simple[sm=headbang.gif]
Old Oct 10, 2006 | 08:17 PM
Sheldon's Avatar
Sheldon
Default RE: Seat Removal - Damn Bolts
try a T-45 torx bit
anubisss's Avatar
anubisss
Get em at sears
Old Oct 10, 2006 | 10:05 PM
Dunk 2's Avatar
Dunk 2
Thanks guys!!!
Old Oct 11, 2006 | 02:42 AM
Luxe's Avatar
Luxe
What the heck are you guys talking about..... This is a Deluxe, right... Use a standard screw driver to remove the pass. pillion rear center bolt. Lift & pull it back, this exposes two thumb wheel type nuts. Use your fingers to undo the knurled nuts & then lift off the rider seat. The Deluxe is likely the easiest two piece Softail seat to remove. You do not need to remove the bolts holding the fender struts.
Old Oct 11, 2006 | 05:56 AM
Trailfndr's Avatar
Trailfndr
Easiest seat ever....Like Luxe stated, a simple screwdriver is all you need.
Frost
Jan 30, 2018 09:12 AM
onmyrocker
Apr 8, 2013 11:09 AM
AmericanMuscle
Sep 14, 2012 08:37 PM
Striker951
Jan 12, 2011 02:10 PM
Pilzner
May 21, 2007 11:48 PM
