Worst luck
Old Mar 6, 2011 | 03:53 PM
Smug's Avatar
Smug
We went through all of this, and you didn't say where it was. WTF ? (LOL)
Old Mar 6, 2011 | 03:57 PM
KeeBee's Avatar
KeeBee
haha sorry I don't know the names of everything yet. It was laying sideways against the shifter lever and some kind of silver plug of some kind. Not sure what the name of it is. Since the key was black against the black case it was well hidden. From the top you could not see it at all. Only way I saw it was up on the lift.
Old Mar 6, 2011 | 04:15 PM
Augustus's Avatar
Augustus
http://www.youtube.com/watch?v=YKQcx1jzn4k
Gotta give ya yur chops for first, tryin, second for askin the questions, third, havin the patience to see it through to the end & last of all succeeding.
Keep up the good work
Old Mar 6, 2011 | 04:27 PM
lp johnny's Avatar
lp johnny
All part of the journey....when you've had enough..go in and take a break...soon it'll be nagging ya to get back out..usually things go much better!
Old Mar 6, 2011 | 04:45 PM
dansax's Avatar
dansax
You have my luck. Murphy's Law. That's why I only do the easiest of things and pay to have the rest done.
Old Mar 6, 2011 | 05:48 PM
nikonf8's Avatar
nikonf8
Default find
ditto with smug said it will show up
Old Mar 6, 2011 | 08:31 PM
KeeBee's Avatar
KeeBee
It's all good I posted during a break I was taking.
Old Mar 6, 2011 | 10:06 PM
cpiad's Avatar
cpiad
Account Closed
Originally Posted by KeeBee
Having the worst luck this weekend. Trying to finish up my exhaust install I dropped an allen key between my gear drive and engine some place and it did not fall out the bottom. Took out the shift linkage can't see it any where. Do I have to remove my gear drive cover to find it or is that a sealed unit and I don't need to worry about it? Figuring when I am riding down the road it will fall out at some point.
Just don't want to damage anything. I have to be the worst newb Harley guy on these forums.
Don't feel bad....I been wrenching 40 years and I dropped 1/2 socket while making sure my exhaust header bolts were tight....out came my mirror on a handle....super bright LED flashlight and craftsman telescoping magnet .... and I found the little bastard. Get one of the smaller head telescoping magnets....start probing directly below the drop point. Then as best you can move a bit around and down. More than likely the key is wedged somewhere. My keys are black and my engine/tyranny covers are black...so if I drop one in a tight spot...its a bitch to find since there is no contrast. I don't think there are any open areas....but....if u cannot find it ....get your air compressor..dial it to 120 psi...and blow air into the gap where u dropped it.. see if u can move it around. Still can find it....raise rear wheel....put tran in neutral....spin tire a few revolutions...listen.... hear for a clink or clink....if u still can't find it....you can either ride it at this point.....or hope for the best. Only other idea comes to mind is careful aim of a pressure washer. Calm....thought out approach is best. We all fuxx up...its the only way to know you are actually doing anything.
Dutch
Skippy49
May 7, 2016 10:10 PM
deez nuts
11
Aug 28, 2012 06:29 PM
Drooly
May 26, 2009 10:48 PM
abate1
Shovelhead
Oct 17, 2008 03:32 PM
boom215
Jan 31, 2007 02:32 AM
