Can't remove instrument panel!!
Old Mar 7, 2011 | 11:01 AM
Mcrider996's Avatar
Mcrider996
6th Gear
Default Can't remove instrument panel!!
I have an '06 nighttrain and am trying to remove the instrument panel from the fuel tank but the acorn nut just spins. I am guessing from the pictures I have seen underneath that the bolt is "locked in" on top of the fuel pump section. I think someone has used industrial strength lock-tite and the bolt has become dislodged from where it locks in.........any suggestions?
Thanks!!
Old Mar 7, 2011 | 11:10 AM
Mike T's Avatar
Mike T
You're probably gonna have to cut that nut off.
Old Mar 7, 2011 | 11:14 AM
watchluvr4ever's Avatar
watchluvr4ever
You're not the first person on this forum to have this problem. Like the OP said you may have to cut it off.
Old Mar 7, 2011 | 11:15 AM
Mcrider996's Avatar
Mcrider996
6th Gear
That's what I was thinking too! I'll take a look at the parts breakdown of the bike to make sure it's what I think it is before I put a cutting wheel to it......and give some time for other suggestions....
Old Mar 7, 2011 | 11:18 AM
ThunderBueller's Avatar
ThunderBueller
The bolt is in a slot. When I've had this problem I've used a little force, and protected parts with towels, and pushed the dash towards the front of the bike and the bolt has come out of the slot and then you can remove the console.
Old Mar 7, 2011 | 11:22 AM
Mcrider996's Avatar
Mcrider996
6th Gear
Thanks Thunder! I'll give that a try later on today and I'll post the results......
Thanks guys!
Old Mar 7, 2011 | 11:24 AM
watchluvr4ever
I thought so but wasn't sure.
Old Mar 7, 2011 | 12:51 PM
JakesDad1's Avatar
JakesDad1
Yeh, that bolt's all thats holding it. If its half out, just push forward and it will pop off.
Old Mar 8, 2011 | 05:05 PM
Mcrider996's Avatar
Mcrider996
6th Gear
No luck getting the bolt to pop out of it's slot. Used as much force as I was willing to push against it but no luck......the good news is I was installing an LED fuel gauge and realized I didn't need the tank all the way off........at least not yet anyway....
Thanks for the helps guys.......much appreciated!!
ccoombs7
Apr 10, 2018 07:27 AM
ejvette
Jan 19, 2017 06:33 AM
Robmitch49
Jun 8, 2012 01:03 PM
GITRCustomed
Jan 15, 2010 07:30 PM
ironhorse62
Exhaust System Topics
Dec 1, 2007 05:01 PM
