Why does HD make their engines like this?
Old Mar 7, 2011 | 01:41 PM
Wabbit's Avatar
Wabbit
Default Why does HD make their engines like this?
Hello all,
On my continuing quest to understand all things HD in preparation to buy my first Fat Boy, I am doing a lot of research. I've never been into working on cars or anything, but I understand that doing some of your own work on your bike adds to the enjoyment, and I want to understand more about what I am riding than just how to stay upright.
So, here are a couple questions I hope some of the more learned folk might be able to help me with:
1) The HD is known for having a 45 degree V (except for the V-Rod, which is 60). Why is this such a big deal that it is mentioned at the beginning of every description of a HD engine? Does this have some sort of effect on how the engine operates? If it is so well established, why did they go to a 60 degree V on the V-Rod?
2) I understand that the unique HD sound comes from having a single pin connecting the pistons, and that rather than having a synchronized firing, it causes a pause between each pair of firings, giving it the HD sound. Can anyone tell me why they do this? Is there any reason, other than the sound? I can imagine that they may stick with it today to maintain the sound, but I doubt the original design was to get the sound. Is there any other advantage to this design?
Thanks for any help!
Old Mar 7, 2011 | 02:06 PM
cameraboy's Avatar
cameraboy
I am anxious to hear the answers to these questions as well. I don't know of any mechanical advantages to the engine set up.
Old Mar 7, 2011 | 02:16 PM
felixsum's Avatar
felixsum
Search is your friend,
https://www.hdforums.com/parts-and-a...nd-history.php
Old Mar 7, 2011 | 02:20 PM
cameraboy's Avatar
cameraboy
That link answers none of the OPs questions, aside that 45 degrees fit in the frame.
Caseyx's Avatar
Caseyx
It's a trade-off between the nostalgic sound vs performance. There is something visceral about the sound, it hits something deep down and not many other sounds have the same impact on me, especially in the middle of a pack of HD's just idling.
Wikipedia has some good stuff on the V-twin...here is an excerpt from one of the pages. Hope this helps some. They have even done physch studies on how thier sound effects the brain...
http://en.wikipedia.org/wiki/Harley-...vidson_engines
The classic Harley-Davidson engines are two-cylinder, V-twin engines with the pistons mounted in a 45° "V". The crankshaft has a single pin, and both pistons are connected to this pin through their connecting rods.[6]
This 45° angle is covered under several United States patents and is an engineering tradeoff that allows a large, high-torque engine in a relatively small space. It causes the cylinders to fire at uneven intervals and produces the choppy "potato-potato" sound so strongly linked to the Harley-Davidson brand.
To simplify the engine and reduce costs, the V-twin ignition was designed to operate with a single set of points and no distributor. This is known as a dual fire ignition system, causing both spark plugs to fire regardless of which cylinder was on its compression stroke, with the other spark plug firing on its cylinder's exhaust stroke, effectively "wasting a spark". The exhaust note is basically a throaty growling sound with some popping. The 45° design of the engine thus creates a plug firing sequencing as such: The first cylinder fires, the second (rear) cylinder fires 315° later, then there is a 405° gap until the first cylinder fires again, giving the engine its unique sound.[76]
Old Mar 7, 2011 | 02:21 PM
Wabbit's Avatar
Wabbit
My google-fu is not so good. But reading that, it looks like 45 degree angle is simply a traditional thing from the first bikes, with no other mechanical purpose. So why did they change to a 60 degree V for the Revolution engine?
It also doesn't mention anything about why they use the single pin thing that leads to the sound.
Old Mar 7, 2011 | 02:23 PM
cosmic tang's Avatar
cosmic tang
strange
Old Mar 7, 2011 | 02:26 PM
Wabbit's Avatar
Wabbit
Thanks, I think that confirms my suspicions, that it doesn't really mean a better running machine, but sticks to the tradition of the sound. I guess I am just not used to how important that sound is (I like the look of the bikes), because it reminds me of how my first car sounded when it was about to croak.
Thanks for the links, too, that will give me some more study material.
Old Mar 7, 2011 | 02:27 PM
SMF's Avatar
SMF
Because the vrods motor is supposed to be hi performance, and I believe it was designed by porche
Old Mar 7, 2011 | 02:29 PM
DyNaBoB's Avatar
DyNaBoB
porche helped hd put there drag bike motor into mass production....
