07 softail cable routing
Old Mar 13, 2011 | 07:34 PM
mars636's Avatar
mars636
Default 07 softail cable routing
Hey i was wondering if someone could take a picture of the throttle and clutch cables around the triple tree area, i am just wondering if they are supposed to be routed through the TT or behind it.
I was just doing some maintenance on my bike and when setting the throttle and idle cables i noticed with the bars at full right lock the throttle will not snap back into place. the cable just dont look right the way they are routed right now.
Cheers
Old Mar 13, 2011 | 07:45 PM
dsonnenberg's Avatar
dsonnenberg
I have an 07 standard with beach bars right now and my cables are not routed through the triple trees. Sorry no pic
Old Mar 13, 2011 | 07:49 PM
mars636's Avatar
mars636
Thanks for checking, did you notice if they are routed in front or behind the triple trees?
Old Mar 13, 2011 | 07:55 PM
SpicOfTheDevil's Avatar
SpicOfTheDevil
behind 3ple tree
Old Mar 13, 2011 | 10:27 PM
mars636's Avatar
mars636
Thanks! i guess mine are routed the right way, guess i will try and get some cable lube and see if that fixes it.
Old Mar 13, 2011 | 10:45 PM
County98's Avatar
County98
If it helps at all, after I changed to the SB bars, I noticed that at FULL right, the throttle was closing slower also. I just dorked around with it some and it's still slower than the other way, doenst "snap" closed, just slower. It's only at FULL lock, so I'm not worried about mine anymore.
I'm pretty hopeful I never find myself doing a full lock turn at more than a walking pace, lol.
Never checked it with the stock bars on there, so dont know if it was always that way.
Old Mar 13, 2011 | 10:50 PM
mars636's Avatar
mars636
Yup that helps thanks. I just found it a bit weird how the lines looked, didnt look routed correct. If yours is getting hung up with the sb bars i am sure they are routed the same as mine
Old Mar 13, 2011 | 11:54 PM
County98's Avatar
County98
Actually, that's why I ended up messing with it forever. They way the cables are routed shouldn't effect the way they work, that's why they're jacketed cables. Shouldnt be any more slack no matter how they're bent.
Guess they're just they're just not terribly slick internally and there is some friction at full right.
Old Mar 14, 2011 | 06:42 AM
jimmers1817's Avatar
jimmers1817
Sounds to me like it's an adjustment issue. They tell you to turn the bars lock to lock while adjusting the idle/throttle cables. But if you've already done that I guess it could be a cable routing issue.
Old Mar 14, 2011 | 11:30 AM
mars636's Avatar
mars636
i have adjusted the cables and i will try the lube today. it is just when i am at full right lock there is as 180 turn the cables have to make which is what i am thinking is hanging it up
