Removing the Front Fender?
Old Apr 4, 2011 | 07:05 PM
DeluxeHog05's Avatar
DeluxeHog05
Question Removing the Front Fender?
Is it possible to remove the front fender of my 2005 Deluxe without taking off the front wheel? I don't have a lift yet. Will it fit between the forks? Any advice is appreciated.
Old Apr 4, 2011 | 07:23 PM
SMF's Avatar
SMF
Yea thats how i remove mine, just lift the bike, and roll the fender back counter clockwise carefull not to drop it bro.
Old Apr 4, 2011 | 07:59 PM
HEMI Army's Avatar
HEMI Army
Which way is counter clockwise?
Old Apr 4, 2011 | 08:03 PM
SMF's Avatar
SMF
Down, its just common sence bro if you pull up on it you can see that the flared bottom of the fender is going to hit.
Old Apr 4, 2011 | 08:34 PM
DeluxeHog05
Bobber, do you have to lift it? Is there room enough for it to slide out with the wheel turned all the way? No lift here
Old Apr 4, 2011 | 11:02 PM
levinale's Avatar
levinale
Dont think you'll be able to remove it without jacking it up... Piece of advice - wrap up the fender with some plastic, it's easy to scratch it when you pull it out...
Old Apr 4, 2011 | 11:21 PM
JIMSFBL's Avatar
JIMSFBL
"If you do not want to scratch the fender" jack the front of the bike up at least to extend the forks a bit (this gives you that extra little bit of room).
Turn your wheel/forks all the way to the left, then slide it out through the backside of the forks.
The reason I quoted this message is because wrapping it is not a bad idea! But after you have done it a few times you figure it out, it's just the first time that will scratch it hehe. Be berry berry cawful.
Old Apr 5, 2011 | 12:41 AM
SMF's Avatar
SMF
Nah bro you have to jack it up, you can see if a friend will lend you one or use a car jack and some pieces of wood bro
Old Apr 5, 2011 | 04:08 PM
DeluxeHog05
Thanks for the tips guys. Using a car jack seems a little sketchy with my luck I will have a bigger problem than a dented fender. (I can see the bike crashing over). Maybe I'll just stop at Sears and get a cheapy bike lift.
RKC1965
2014-2024 Touring Models
Sep 12, 2016 07:25 AM
camden
Dec 28, 2014 03:12 PM
davessworks
Mar 28, 2010 03:09 PM
English Pete
Jan 29, 2010 05:31 PM
GEESE
Sep 25, 2008 07:53 PM
