Heritage exhaust
Old Apr 6, 2011 | 04:18 PM
inkslngr7's Avatar
inkslngr7
2nd Gear
Default Heritage exhaust
Ok here goes..I don't know if this has been addressed before so I'm gonna go ahead and ask.
I have an 03 Heritage classic and want to put the stock dual exhaust setup off a Heritage springer on my bike. Mine is fuel injected. I aquired a complete set off a 2007 Heritage springer. I noticed that on the aftermarket true dual setup they go from 2000-2006. Will there be a problem putting the pipes from the 07 on my 03 ?
Old Apr 6, 2011 | 06:23 PM
Gman in NC's Avatar
Gman in NC
I wouldn't think that will work. You're going from 88 to 96 inch motors. I think the stroke/length of the cylinders may be different. This would throw everything off.
Old Apr 6, 2011 | 06:57 PM
ChromeJunkie's Avatar
ChromeJunkie
The reason for the difference is that the 07 and newer bikes have O2 sensors. get a set of sensor plugs and you will be fine.
Old Apr 6, 2011 | 07:02 PM
jlasoftail's Avatar
jlasoftail
+1 A lot of pipes for the Heritage list from like 86 and up, but pre 07 need O2 sensor plugs. I'm sure you'll be fine. The engine size really shouldn't make a difference. Not sure what you'd have to do for tuning, but you should be able to make it work.
Old Apr 7, 2011 | 07:19 PM
inkslngr7's Avatar
inkslngr7
2nd Gear
Thanks for the replies guys....I figured I'd have to get plugs for the o2 sensors. I was hoping that there weren't any frame changes or differences to where the pipes wouldn't fit at all. My Heritage is a 98" also anyway..Has Screamin Eagle big bore kit.
Old Apr 7, 2011 | 07:44 PM
ardakota's Avatar
ardakota
i run 07 stock headpipes on my 03 you will have to use the mounting bracket off the 07 pipes.
Old Apr 8, 2011 | 03:56 AM
ardakota's Avatar
ardakota
also the plugs i got to plug the o2 holes were 18mm car oil drain plugs from oreilly auto wasnt quite 5 bucks for the pair.
medic2931
Oct 29, 2020 12:18 PM
CyGlide
Jan 24, 2016 06:15 PM
joe297
Aug 26, 2010 01:14 AM
BlackRob
Jul 6, 2009 08:39 AM
Howie Feltersnatch
Exhaust System Topics
May 20, 2007 12:44 PM
