a loud squeak
Old Jul 1, 2005 | 02:38 PM
Ebe's Avatar
Ebe
Stage I
Default a loud squeak
Any ideas? I have a noise, a loud squeak coming from my 99 FXSTC. It only happens when I am shifting to the next gear, up or down. As soon as the clutch take hold I hear a short loud squeak, if I am coasting down a hill and letting the motor slow the bike down I hear it. It’s hard to tell where is coming from but definitely from the area of the engine and I believe from the left side.
Old Jul 1, 2005 | 03:23 PM
HDF Tech's Avatar
HDF Tech
Default RE: a loud squeak
Is it just one squeak or a constant squeaking when it happens?
As you slow down, sounds like it could be a tight belt problem. Try spraying the belt with some silicone on the inside (tooth side) and see if it changes it.
Also check the pivot shaft for the shifter ( a common problem) it probably needs greasing. You can also install a grease fitting in the boss by drilling and taping it , then install the grease fitting.
tennessee streetglide
Aug 9, 2009 08:36 PM
forever young
Nov 28, 2008 09:24 PM
mmgogos
Apr 19, 2008 01:35 AM
94 Heritage
May 15, 2007 09:24 AM
LuckyRoadKing
17
Aug 15, 2006 06:26 PM
