Hard to pull clutch
Old Apr 13, 2011 | 09:06 AM
GIJoe65's Avatar
GIJoe65
Stage I
Default Hard to pull clutch
I have an 05 Fatboy that has a hard to pull clutch. What can I do to make it easier to pull without using all my strength? Should I change the all the fluids, adjust the clutch cable, lube the cable, and or add an Ez (reduced effort) clutch?
Any help would be appreciated.
Thanks
GIJoe65jokaelin@optonline.net
Old Apr 13, 2011 | 09:09 AM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Start by lubing the cable and adjusting it. Report back with the results.
Drew
Old Apr 13, 2011 | 10:22 AM
JPL's Avatar
JPL
Sorry for my stupidity but how do you lube the clutch cable? would it say in the service manual?
Old Apr 13, 2011 | 12:17 PM
bikersurgeon's Avatar
bikersurgeon
remove clutch cable....cut corner out of ziplock bag....insert cable end in bag hole...tape bag to cable.....fill ziplock with oil.....hang bag from garage rafter (not in the house your wife will kill you....trust me).....wait till you see oil on other end of cable (hours later)
Old Apr 13, 2011 | 01:26 PM
JPL's Avatar
JPL
Perfect man thank you!
Any specific Oil to use?
Old Apr 13, 2011 | 01:35 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Or, you can buy a bottle of Dri Slide and stick the needle into the end of the cable and squeeze.
Drew
Old Apr 13, 2011 | 01:40 PM
poppavein's Avatar
poppavein
I would stay away from olive oil.
Old Apr 13, 2011 | 02:15 PM
stevelonewolf's Avatar
stevelonewolf
Drew
LMAO!!
Old Apr 13, 2011 | 02:25 PM
bikersurgeon
In the past I've just used 30 wt motor oil. when a cable is so jacked it's hard to pull,
dri-slide usually wont work unless you hit it every 10 minutes for 4 hours...granted the only cables I've ever had to treat are motocross bike cables....probably much nastier than most harleys...except mine lol.
Old Apr 13, 2011 | 02:34 PM
frontiercat's Avatar
frontiercat
Maybe even check cable routing...unless it just started getting hard to pull...
Mfd6049
Apr 8, 2014 09:36 PM
arbound1223
Aug 22, 2011 10:56 AM
simmonsp5
Jun 27, 2011 04:22 PM
jims79flh
Mar 29, 2011 09:01 AM
HDF Tech
Oct 8, 2005 10:33 AM
