Has anyone had code p1654?
Old Apr 16, 2011 | 10:25 PM
metaldoctor21's Avatar
metaldoctor21
Default Has anyone had code p1654?
I just got code p1654 which is current tachometer high 4.6 im self diagnostics. I have know idea what that means. If anyone has had this problem or has any idea what it means i would greatly appreciate the answer. thank you.
Old Apr 17, 2011 | 04:39 AM
Keithhu's Avatar
Keithhu
From this: http://watamix.com/harley/ on that page it says it is a historical reading, so I'm guessing it records the highest tach figure. Was there more information on that reading? If so I'm guessing it was the actual tach figure which represents the actual reading.
Old Apr 17, 2011 | 07:36 AM
metaldoctor21
A couple of places i looked listed it as a current and as a historic code. I cleared it three times and it comes right back on. That is why i figured it was a current code. What happened was i added a tach wire to the #3 slot in the ecm plug. I hooked everything up and tested it and it worked fine. Then i bolted everything in and ran and tucked all the wires back in place. I started it back up and the tach would not read and the check engine light came on with that code.
Old Feb 16, 2016 | 05:47 PM
Sal C's Avatar
Sal C
I know that this is an old thread, but I got a 07 Low Rider, that I was hooking an
aftermarket tach to, and same thing happened..Same code..Cleared it, but keeps on coming back and check engine lite comes on. Did u ever figure out how to get it permanantly erased?
Old Feb 17, 2016 | 03:26 PM
metaldoctor21
I ended up unhooking the tach from the ecm and hooking it back up through the coil wires. The code never went away. When I sold the bike I ended up putting in a new ecm because I didn't want to sell it with the check engine light on. Harley told me it was a false code and could not be cleared. I rode the bike for a year before I switched the ecm. It didn't cause any problems except it was annoying looking at the light all the time.
Sal C
Jan 21, 2026 12:30 PM
metaldoctor21
May 15, 2011 10:13 PM
ReddRidder2003
Aug 10, 2007 10:40 AM
gilbertb11
Jan 28, 2007 08:29 PM
Scout
Jun 24, 2005 02:50 AM
