Softail electrical problems
Old Apr 18, 2011 | 06:27 PM
Mr.Black's Avatar
Mr.Black
Stage II
Default Softail electrical problems
I have an 06 nightrain with an electrical issue. I turn the power on and the headlight and taillight come on, and so do the turn signals. I look down at the speedometer and the odometer is not on, i try the turn signals and they do not flash, the bike is running fine, I take it down the street and the speedometer is not working nor is the breaklight when I press the break pedal or pull the lever. Any suggestions?
Old Apr 18, 2011 | 06:55 PM
hspring03's Avatar
hspring03
Check the accessory fuse.
Old Apr 19, 2011 | 08:01 AM
handyhoward's Avatar
handyhoward
If it not the fuse the next place to check is all the connections under the dash... this is the most neglected part of most bikes, yet is critical in their proper operation. Make sure each and every connector is snug and clean and has a light coating of dielectric grease... especially the ignition array.
Camero
May 17, 2019 08:29 AM
hueckstaedt
May 3, 2018 07:03 PM
ianbword
Electrical/Lighting/Alarm
Jun 30, 2016 02:01 PM
JOEWAG
Aug 20, 2013 08:16 AM
JOEWAG
Aug 18, 2013 12:01 PM
