Removing reflectors off front forks
Old Apr 21, 2011 | 09:06 AM
oct1949's Avatar
oct1949
Hair dryer, and study pressure. then clean up with adhesive remover.
Old Apr 21, 2011 | 09:15 AM
hdgzr's Avatar
hdgzr
Yes, the Goo-Gone has a light abrasive and will cut through the clear coat if applied to vigorously. I also used the hair dryer method, then a small flat blade screwdriver to pry them off. Rubbed most of the remaining adhesive off with my fingers. WD-40 for the residue.
Old Apr 21, 2011 | 08:28 PM
DGRF250's Avatar
DGRF250
Default Reflectors
Hair dryer, WD40, and a plastic putty knife. After removing reflectors use plastic putty knife and WD40 to remove adhesive.
Old Apr 21, 2011 | 09:48 PM
hdonly4me's Avatar
hdonly4me
Thanks, wd-40 & hair dryer worked great!
Old Apr 22, 2011 | 07:30 AM
Misbehaven's Avatar
Misbehaven
After pulling off the reflectors nothing is faster then a 3M Eraser Wheel.
Old Jul 18, 2011 | 12:05 AM
matwal84's Avatar
matwal84
Just removed mine on a Deluxe. I just took a vice grip to the reflectors on the front forks and pried the reflectors off. No reminents of sticky double sided tape left on forks. It took literally 2 minutes. The rear reflectors were a different story. Used some fishline and DW40. Took a few minutes longer. All done without any issues.
Old Jul 18, 2011 | 01:16 AM
nikonf8's Avatar
nikonf8
Default reflectors
ditto on what brett said fishing line, hair dryer, and goo be gone.
Old Jul 18, 2011 | 01:26 AM
Little Mike's Avatar
Little Mike
Originally Posted by 1hellbent
Will the Goo-Gone attack the clear coat on the lowers?
Lowers...on a Heritage Springer??
Old Sep 5, 2011 | 02:19 PM
Truckertom's Avatar
Truckertom
Thanks all...........used hair dryer and a little rubbing alchohol to remove residual goo....works like a charm!!
Old Sep 6, 2011 | 06:51 PM
2020ranch's Avatar
2020ranch
3rd Gear
fishin line and WD40
