Removing reflectors off front forks
Old Dec 23, 2011 | 02:47 PM
Smurf14's Avatar
Smurf14
Stage IV
I used Goo-Gone and a small screwdriver now got some scratches and marks and idea how to get them fixed?
Old Mar 10, 2013 | 09:19 AM
LoudPipes's Avatar
LoudPipes
1st Gear
Hair dryer and a plastic putty knife, took 3 minutes. Cleaned residue, which was very little, with nail polish remover.
Old Mar 10, 2013 | 11:07 AM
Bone Doc's Avatar
Bone Doc
This may be a learning experience for you. In the future, I wouldn't use metal objects (eg: screwdrivers) to scrape dirt, residue, etc. off of metal, especially chrome. They scratch as you found out. Notice the posts to this thread recommend PLASTIC scrapers.
If the scratches are in chrome, they are likely permanent and the only fix is to rechrome. You can try a metal polish like Simichrome but they will not disappear. Hopefully they are only fine scratches and not very noticeable.
If the scratches are in aluminum, like lower legs, you can sand the scratches out using wet sandpaper or steel wool and an abrasive metal polish. The depth of the scratches will determine how aggressive you will need to be. You can search the forum for "polishing aluminum". I am not suggesting you should proceed to finish the aluminum to a highly polished surface but it will contain information for you to help remove the scratches.
Good luck with it.
Old Mar 10, 2013 | 12:14 PM
jwilson77's Avatar
jwilson77
I put a little goo-gone on around the reflector and let it sit about an hour. Came back, gave 'em a twist and popped right off. A little more goo-gone on a folded up paper towel and let it sit on the remaining adhesive for a while. Came back, rubbed it clean and good to go.
Kowan's Avatar
Kowan
I used a small block of wood as a fulcrum and to protect the surface.
Used a large screwdriver to pry the reflectors off.
Chrome polish to remove the very small amount of adhesive left on the forks and wax to remove it off the swing arm.
Old Mar 10, 2013 | 01:16 PM
mlodzik13's Avatar
mlodzik13
is there any special way to take them off of denim paint?
Old Mar 10, 2013 | 01:34 PM
Kowan's Avatar
Kowan
Since the primmer, I mean demin isn't a smooth finish, I'd use the goo gone to loosen the adhesive before removing them.
Old Mar 10, 2013 | 06:55 PM
smokeygold's Avatar
smokeygold
3 freakin pages on removing reflectors and I'm reading them! Winter in New England!
Old Apr 3, 2013 | 04:09 PM
Govno's Avatar
Govno
Okay. Now that I have read all this and know "how" to remove my reflectors, lol, I was wondering if anyone took them off an older bike and if there was discoloration on either the aluminum or the paint? I have a 2003, so it's 10 years old...
Old Apr 3, 2013 | 04:26 PM
Kowan's Avatar
Kowan
I'd imagine the paint under the rear reflectors would look new compared to the sun and normal wear on the rest.
