I'll have to find a shell then. I can never find a pump without a 10% decal on it. This is on the states web page.
President Bush signed into law the 2005 Energy Policy Act on August 5, 2005, which includes a 7.5 billion gallon renewable fuels standard by 2012. This mandates the use of ethanol (and biodiesel) in the American fuel supply. Annual U.S. production of ethanol has surpassed the 4.85 billion gallon mark as of January 1, 2007.
I have always run 87 octane in my 03 Fatboy w/ Carburetor... runs great even with 15% ethanol. Have been all over Canada, Mexico, and the USA on this bike and the 87 octane is the same everywhere. I did change out all the rubber parts in the fuel system to accommodate for the ethanol... over time it tends to disintegrate rubber. It was no big deal to find the proper parts and swap them out.
In Kansas, most of our gas is pure gas. You can buy ethanol if you want, but most stations sell pure gasoline also.
I worked for a refinery for many years, and I can tell you that the governmernt regulates gasoline formulation to the point that all gasoline is the same. The only thing different, is the additives that each company uses. We sold gasoline to Phillips, Standard, and many other gas companys. When the tankers came in to load, we added the additives that that company used. So at least in this part of the country, if you buy Shell gasoline, it may be from any refinery, but it will have Shell additives.
True JK, I managed a Shell station many moons ago when gas was .28 cents a gallon, (now you know how old I am) and that was before additives. When I travel and I do quite a bit, I try to use the major brands when ever possible, and so far even when I use the 10% I HAVE HAD NO ISSUES. When I rode to Alaska in 2008 you were pretty much at the mercy of what they had. Still had no problems. I am of the old generation, that you run what ever makes you feel good and don't cause any problems. So that's why I use the 89 most all of the time and occasionly run a tank of 91 when the temps get warmer, soon I hope.
Do not use low grade fuel....thats all there is to it,,,,as for the seals,,,if they start to leak ,,,its not from the type of oil,,,if the type of oil caused seals to leak,,your car, truck, lawn mower, boat motor, and so on ,, would have problems too....
I was wondering can low grade gas cause seals to breakdown cause I have a 2000 something model sportster that has smoke coming from the top of the front head I don't know what's up with it any help would be much appreciated
That's not much to go on and I'm not too sure what it has to do with fuel usage. Maybe start a new thread with some details and you'll probably get better responses.
As far as Ur oil getting dirty, really dirty that fast (700miles) makes me wonder,, What filter U using.
Is it a HD or aftermarket filter,????
Some aftermarket filters don't have the right flow pressure and could be putting Ur oil in the BY_PASS mode all the time..
This is the big reason I use different oils than HD,, but I won't use any other filter.
Also how long have U owned the bike,?? How many miles on her and how was she maintained before.???
She may have been neglected somewhere along her life.
So is it better to run a lower octane but ethanol free gas or a higher octane 10% ethanol and add a stabilizer? I hate the ethanlo and what it does to alot of motors so I found a local station that has ethanol free but it is only like 87 octane I think. I have been using it no problems and no knocking.
There's nothing wrong with having ethanol in gasoline. In fact, many have switched their ultra-high performance engines over to E-85, rather than using race gas. It's about the best thing to come along for the serious hot rodder in a long time. I have a buddy making 1800 horsepower out of a Big Block on E-85. And most of the "pump gas" dyno shootout winners are using E-85, when it's allowed.
