08 fxstc - Fuel capacity?
Old Apr 28, 2011 | 11:54 PM
Stretchman's Avatar
Stretchman
Question 08 fxstc - Fuel capacity?
According to the specs on the bike, the fule capacity should be 5 gallons. Today I hit reserve on the turnpike, and according to the mileage indicator, I had about 10 miles left before going dry. The yellow fuel icon was on, and I was a little nervous, since I never had it down that low before.
When I filled up, the bike took 3.9 gallons. I couldn't have squeezed more fuel into it if I had wanted to. If the bike hold 5 gallons, where is that other gallon hiding?
Just curious.
Old Apr 29, 2011 | 04:57 AM
Blk and Chrome's Avatar
Blk and Chrome
on the bright side, you will never run out of gas but thats how good the fuel guages are, mine has been the same as yours since new, they are never right
Old Apr 29, 2011 | 05:55 AM
brettnbama's Avatar
brettnbama
part of you fuel capcity is taken up by the fuel pump in your tank....
Old Apr 29, 2011 | 08:34 AM
silvrbill's Avatar
silvrbill
Quit using the miles to go feature.
Start setting your trip odometer at 0 when you fuel and start looking for a station around the 150-160 mark.
That gives you another 30-40 miles before you're on fumes.
Old Apr 29, 2011 | 10:38 AM
Wide_Open's Avatar
Wide_Open
Yup. Do it the good old fashioned way.
Old Apr 29, 2011 | 11:32 AM
Sgt_Jim's Avatar
Sgt_Jim
that's about right.. my light comes on, and when I fill it up shortly after I only take between 3.9-4.2 gallons.. the gauges aren't very accurate, but my digital range meter is pretty close to what it should be
...but i do the math every time at the pump:
Milage/gallons replaced = mpg..
5*mpg = total range..and i subtract like 30-40 from that number and when i hit THAT number is when i look for a station.
Old Apr 29, 2011 | 12:07 PM
Crazy Biker's Avatar
Crazy Biker
When my fuel light comes on I know I have about 40 miles until totally out.
'07s don't have miles to go feature.
Old Apr 29, 2011 | 12:14 PM
Fulano's Avatar
Fulano
I get a little antsy every time my fuel light comes on too. Then I get upset that I only fill up 3.5 gallons. The one time I filled it all the way up? The light came on, I rode it until the orange light came on, then finally filled up. 4.9 gallons. Too close for me to try it again, but it's unfortunate the lights aren't more consistent for me.
I figure after 180 miles, I need a station, just to be safe. I'm averaging 45-48 mpg and almost consistently get over 200 miles on a tank. The 'almost' part keeps me looking for gas at 180 though. I'll have to get used to not using the miles to go feature. I leave that on and I think that's what gives me anxiety when I ride.
Old Apr 29, 2011 | 03:45 PM
Bikenator's Avatar
Bikenator
From: in a trailer next to a ditch in South Florida
My '07 has the same tank you have. When the low fuel light comes on I can count on about 40 + more miles in the tank. Mine means there' s about 1 gallon remaining and it usually takes 3.9 to 4.2 gallons to fill, my fuel gauge seems to be accurate. That 5 gallon capacity accounts for the presence of the fuel pump and filter in the tank...it's NET capacity.
Old May 1, 2011 | 07:09 AM
Stretchman's Avatar
Stretchman
Thanks for answering my questions.
