Tail light
Old Oct 24, 2006 | 02:21 PM
Ronbo's Avatar
Ronbo
Default Tail light
I have and 04 FXSTSI, I installed a side plate, the cut off the bob tail plat holder. What I would like is a tail light that will full the space in the fender, maybe LEDs. Any body have any input?
Old Oct 24, 2006 | 03:40 PM
puckthis's Avatar
puckthis
Default RE: Tail light
check jokermachine.com they have a great tail light set up
Old Oct 24, 2006 | 05:50 PM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
Yea Joker is about the best one, problem is they want a ton of money for it.
As you have one of the older narrower tired versions you might be able to find other sources. Check with Pro-One, Custom Chrome, and some of the other big catalog places. They might be able to supply you with other brands that will fill that hole for you.
Old Oct 24, 2006 | 07:04 PM
Ronbo's Avatar
Ronbo
Thanks guys
Ronbo
Old Oct 25, 2006 | 11:26 PM
JLOCKHART29's Avatar
JLOCKHART29
Check out Drag specalist. The have several typs of cateye tail lights that might work. I made my own bracket by first cutting out a jig from cardboard that fit then stenceling it onto a sheet of stainless and cutting it out w/ a jig saw. Mine is an 04 but the principal is same.
[IMG]local://upfiles/1355/D9199EEB373D4938AC9372012945E777.jpg[/IMG]
[IMG]local://upfiles/1355/3AB9FC9D0AB74382B4F277BDA0DB9D1F.jpg[/IMG]
Old Oct 27, 2006 | 10:48 AM
skips69's Avatar
skips69
Yeah, probably at least a dozen different options for you in filling that rear fender with a tail light - and quite a few for less than $100. That's one of the first mod's I made to my 05' and the 07' as well - hated that small stock tail light. As for the 06' and 07' models though, only a couple that I know of and $200 + for them.................
paulies 07
Mar 12, 2013 05:47 AM
WA7MM
May 29, 2012 10:16 AM
Hawg2008
Jun 21, 2010 10:47 AM
Oldrider
Mar 18, 2008 01:21 PM
floridian46
Jun 9, 2007 12:42 PM
