Question about wind deflectors
Old May 10, 2011 | 08:24 AM
kzoo's Avatar
kzoo
Default Question about wind deflectors
Just got the shield on the heritage and have a couple questions about the lower wind deflectors
Will they allow ample air flow to cool the motor?
Are they easy to install (I am very mechanically challenged)
Do they help with the buffeting from the shield? If I put my feet on top of the crash bar the buffeting is mostly gone
Old May 10, 2011 | 10:06 AM
Steve52's Avatar
Steve52
I put a set on my '10 Heritage last summer. Harley P/N 58125-90B.
Wasn't sure I liked the Walrus tusk look, but they worked very well. I've gotten used to the way they look and wouldn't be without them now.
No negative effect on engine cooling that I've noticed.
Eliminated nearly all of the buffeting behind the shield.
Easy to install, followed the instructions in the box. Took about 30 minutes.
Old May 10, 2011 | 10:08 AM
KumaRide's Avatar
KumaRide
Yes
Yes. The 4 bolts that hold the shield on.
You can smoke a cigar while riding with them installed. And keep you warm in the winter. Mine will come off in a few weeks when temps get around 80.
Try keeping your knees pressed against the tank while riding 50+mph. This stops most buffeting also.
Old May 10, 2011 | 10:24 AM
TheTroupe's Avatar
TheTroupe
Once you get use to the fang look, you'll love em.
Old May 10, 2011 | 11:39 AM
poppavein's Avatar
poppavein
I found that these engine guard "chaps" (lowers) help reduce buffeting and keep you warmer in the winter.
http://www.sagebrushdesigns.com/
The Harley soft lowers have a warning not to use them in less than 50 temps, but these flow air better.
Webo
2014-2024 Touring Models
Nov 20, 2014 06:40 PM
steelerdude1
Sep 18, 2013 05:58 AM
Norms 427
Apr 11, 2013 07:35 AM
GutWrench
May 21, 2012 02:12 PM
fatboyartie
Jun 2, 2009 07:33 PM
