Wierd electrical problem
Old May 15, 2011 | 06:11 AM
FroggyFatBoy's Avatar
FroggyFatBoy
i would be checking grds also.
side note: if you have metal on any type of speed sensor, or the plastic is worn away from contact with the gear or ring, you have bigger problems..
Old May 17, 2011 | 07:44 AM
DaddyKnuck's Avatar
DaddyKnuck
Originally Posted by Sidecar Cycles
Re: FroggyFatboy comment...
side note: if you have metal on any type of speed sensor, or the plastic is worn away from contact with the gear or ring, you have bigger problems...
Both sensors are magnetic and as such they will collect metal. Every time you do an oil change... there's metal present on the drain plug, so it stands to reason it'll be present on the sensors too. The more often you change it the less you'll find.
Any large amount or large pieces do raise an alarm! Bottom line though, it's there, clean it off now and again... call it preventative maintenance because left there, it will throw off readings and eventually help wear away the thin layer of plastic.
Note: The only way the crank could contact the crankshaft sensor is if the bottom end came apart... "in a big way"! Same scenario for the speed sensor in the transmission.
I agree. I've been doing this for a while and it's very unusual for me to come across any magnetic sensor or drain plug that doesn't have at least a fine coating of metallic slivers. I've now pulled the VSS and swapped it with a known good unit and that isn't the problem either.
I'm still scratching my head trying to figure out how the bike can run from the ign or acc position and it's not the switch, and how the speedo and odo are missing and it's not the VSS. The idiot lights work as well as the security light in the speedo itself, so power is definitely getting to the console.
Like I said a weird problem. I'm going to keep asking around. Sooner or later I'll come across someone that says "the exact same thing happened to me."
Old May 17, 2011 | 09:57 AM
FroggyFatBoy
yes i should have said, wear dust is normal and fine.. when i said metal i assume most would understand metal to mean pieces the size of finger nail clippings or small paint chipso.. you know what assume means..
collection of wear dust shouldn't cause the sensor end to wear, there is usually maybe .050 -.100 gap to begin with. the (for lack of better term)" turbulence " in the gap of the sensor and gear should keep the gap consistent or in cases of extreme buildup, slight contact wiping the dust off..
and thats why i said if if the sensor is damaged, "you have bigger problems".. sensor damage usually means a bearing has gone south and letting the shaft run out of true..
Old May 17, 2011 | 10:00 AM
FroggyFatBoy
with the bike starting in acc, i would think that maybe a relay is stuck in the on/energized position.... i don't have a wiring schematic to see what, if any relay that is only energized in start only postion..
Old May 17, 2011 | 01:29 PM
DaddyKnuck's Avatar
DaddyKnuck
That's an interesting thought and easy to check with a nearly identical bike at hand.
Thanks.
Old May 19, 2011 | 11:53 PM
flipstoyz's Avatar
flipstoyz
I've chased the same problem on my 08 train when it had less than 3000 miles. I changed the vss, improved all ground points, and lubed the swith with dilectric grease. The main ground at the rear tank area was a joke. I relocated to direct frame ground and sanded to bare metal contact. 7000 miles later and no more issues.
Old May 20, 2011 | 08:12 AM
HCLASSIC00's Avatar
HCLASSIC00
Originally Posted by Robert M Rooney
My 2000 heritage did the same thing, replaced speedometer sensor on the top of the transmission fixed it. Check conectors before you buy a new sensor.
My 2000 heritage just started doing this yesterday. Engine light comes on, no speedo or odometer. Auto cancel quit working on the blinkers too. When I come to a stop the odometer comes back on and engine light goes off. Guess I will check the sensor.
Old May 21, 2011 | 10:20 AM
DaddyKnuck's Avatar
DaddyKnuck
You can isolate the ignition from the accessory by making a simple jumper, see attached photo! Plug the middle connector in the center position (red wire) of ignition switch harness (that's battery direct). Then place one of the two outside connectors in an outside position, one at a time (red/gray is ignition & red/black is accessory). With one connected there should be no power at the other check with a test light). If there is you have a problem with the starter relay, or the wiring / connectors between the two points, ignition switch & starter relay!
The starter relay explained in other attachment!
Thanks for the advice. I think I've eliminated the relay as a problem. I tested as suggested, and then switched a relay in from an almost identical bike (2002 Heritage Springer.) On the Night Train, bike still started in both IGN and ACC. Putting the NT relay in the springer didn't change anything (it still operated properly). I then switched speedometer heads between the bikes. The Springer speedo works fine in the NT, and the NT speedo doesn't work in the Springer.
However, the NT still allows the bike to start in both positions. Last week I swapped the ign switches and that didn't make a difference. I think I've got a bad speedo head (unless there is a serviceable piece I'm missing), and something else on the NT that isn't the switch or relay that is allowing the bike to start in both IGN and ACC. To make the problem even weirder, this all happened while the bike was sitting during the winter months. It wasn't happening last fall.
Old May 21, 2011 | 01:40 PM
Theglide05's Avatar
Theglide05
as for the bike starting in both the accesory and run position, could the wires for for both be reversed on the ignition switch, possibily the connector being on backwards. just a guess as if you did get those two wire wires back wards it would give you the same sympton
Old May 21, 2011 | 02:29 PM
DaddyKnuck's Avatar
DaddyKnuck
A possibility I considered except the wiring harness loops in a very specific way that indicates that the way it is hooked up is the way it has always been. Plus, this problem developed over the winter when no one could have switched the wires around.
The troubleshooting flow chart in the service manual indicates that as a primary test if the odometer does not display numbers the speedo needs to be replaced. That of course is what I was hoping wasn't the case. If anyone has upgraded to a speedo/tach unit and wants to sell a Softail or Road King speedo from the 99-04 models (part # 67033-99A) send me a PM.
