This is my attempt at covering the grenade. I took the horn cover off my sons Electra and modified it to fit as a grenade cover. Now that i know what to do i will get a after market horn cover and modify it for a custom cover. As far as the ignition goes i took the motor mount off welded a small tab, drilled a hole in it for the ignition switch and bolted the ignition switch through the hole in the tab with the stock nuts,no need to cut the wires. This coming winter i will get the motor mount chromed for a better look. If any questions just ask. Sorry if the pictures are to big.
Thank you and yes it was done by someone else with a zombie horn cover i believe.
I always thought the grenade was just a cover not the complete coil, kind of made me scratch my head a minute.
Mark
