Engine missing
Old May 15, 2011 | 08:46 PM
jlasoftail's Avatar
jlasoftail
I'll try the sea foam. Could be the power commander, and yes it is a canned map. No one around here does dyno-tune, but the local hd shop is getting the stuff to do it. My problems started before that was installed though but the misfire is new.
Old May 15, 2011 | 10:12 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Call fuelmoto and buy a map from them. They have the most extensive database around of maps for the power commander. Load the map and see if that helps. Change your plugs and wires too. These are all cheap possible fixes. As far as the vies, what was the last thing installed before the vibration started?
Drew
Old May 16, 2011 | 12:55 PM
oct1949's Avatar
oct1949
Originally Posted by Mike T
It's probably not anything serious. Try to keep your revs up a little higher. 50 mph in 5th gear is coming close to lugging the engine.
IMO lugging would be different on different bikes. the Andrews 26's pulls our bike fine at 2k rpm's, but I don't do a full throttle accell in 4th, 5th or 6th
Whereas some builds wouldn't let U ride that low of rpms.
According to my print out of Nighriders Speed vs rpms, our 07 at 50mph in 5th is right at 2300 rpms.
In 4 yrs I've ridden quite a bit (mostly 2-up)in 5th at 50-55mph. I will add the cams do help. Wouldn't call it lugging at all.
Old May 16, 2011 | 05:31 PM
jlasoftail's Avatar
jlasoftail
Drew
Yeah, just got the new map from Jamie (glad I bought the pcv at fuel moto) and I'll upload it when the bike's back from the shop. I finally had enough BS from the stealer and told them the better start tearing it apart. The only change before the vib started was a new inner-primary cover and clutch bushing. The stealer says that couldn't possibly be causing the vibration that they say I'm not even having, but I told them they had better start taking things apart until they find something.
Any bets on what my bill is going to be if they don't find a warranty issue?
they are gonna check out all clutch components, compensator, crank...
Old May 16, 2011 | 07:00 PM
kkiley's Avatar
kkiley
My FatBoy developed a vibration between 2,200-2,800 RPM's so bad it would shake the tank. I checked mounts, ignition, anything I could think of before tearing it down and finding my counter balance gear had shifted on the crank. Hope you find your issue soon.
Old May 16, 2011 | 07:29 PM
cpiad's Avatar
cpiad
Account Closed
What year is your Softail and what engine mods?????
Old May 16, 2011 | 08:27 PM
jlasoftail's Avatar
jlasoftail
'09, 103, se 255 cams, s&s a/c, v&h bsl, auto comp release.
Old May 16, 2011 | 10:28 PM
Bluehighways's Avatar
Bluehighways
Sounds like Secondary Ignition System to me. The Secondary Ignition System includes: The Ignition Coil, Spark Plug Wires, and the Spark Plugs. The toughest time for these parts is when the engine is under a part throttle acceleration. With an engine oscilloscope it's fairly easy to figure out which is which pretty quickly. Without a 'Scope as inexpensive as the parts are, I'd try replacing the following parts in the following order (yea, it's called parts changing and it isn't a real elegant way to do this but . . . ) 1.) Spark Pugs, 2,) Spark Plug Wires, 3.) Ignition Coil. Also, there is a reasonable chance that it could be something else: A bad ground somewheere in the ignition and/or computer system, a failing Crankshaft Position Sensor, a bit of water in the fuel, etc. I can tell you that if it wasn't happening before with the old Map, changing the Map isn't going to fix this.
Why a Dealership would NOT have an engine oscilloscope if they are in the business of repairing engines entirely escapes me . . . but then again I forget myself . . . we're talking about a Harley Dealership aren't we . . .
asahi1234
Dec 18, 2010 09:35 AM
cromagnon
The General Motorcycle Forum
33
Jun 4, 2009 03:06 PM
The Old Man
Jan 27, 2008 09:37 PM
RoadGlide07
Sep 15, 2006 12:41 AM
howieheels
Sep 16, 2005 09:54 PM
