Fatcat 2:1 install
Old May 17, 2011 | 05:49 PM
RockerSE's Avatar
RockerSE
New gaskets required! If it's anything like my V&H 2-1 install, the biggest thing I needed and didn't have was 6 hands.
Old May 17, 2011 | 06:19 PM
TheTroupe's Avatar
TheTroupe
You don't need the gasket tool for the s/e flat gaskets. If your system calls for the tapered gaskets, the JIMS tool is worth it IMO.
HaHateMe your deluxe has came with tapered gaskets and may not be right for the D&D as Drew has pointed out.
Old May 17, 2011 | 06:21 PM
HeHateMe's Avatar
HeHateMe
Thanks for the advice.
Old May 17, 2011 | 06:22 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
I found no need for 6 hands as you loosely bolt on the head pipes, and then do the bracket and the muffler. then tighten it all up.
Drew
Old May 17, 2011 | 11:31 PM
Northside's Avatar
Northside
If it takes an hour you got a lot of phone calls or other interuptions. Piece of cake with wobblies.
Old May 18, 2011 | 07:34 AM
rrambo's Avatar
rrambo
Originally Posted by HeHateMe
My deluxe has 120 miles on it. Can I use the same gasket or does it need to be changed?
I would say change it.. I didn't change mine (mine was new too) and I had a leak.. I don't think aftermarket pipes work well with the stock gaskets.. I went with solid copper gaskets.. no leaks now...
Old May 18, 2011 | 07:44 AM
fcsallan's Avatar
fcsallan
This aint brain surgery here. Take the old one off, four nuts on the headpipe, loosen or remove the clamp bolt for the muffler(s) and remove, remove the bracket for the old muffs if this applies, remove head pipe.
Loosely install tailpipe bracket, Remove rear heatshield, loosely install headpipe with new gaskets, install new muffler and make sure everything is aligned to your liking, Have a beer while you stare at the bike, then start from the rear working forward to tighten everything up to factory spec, re-install heatshield, wipe entire system down multiple times with windex to remove all finger prints, again have a cold one, then start her up, take her for a ride and enjoy a job well done.
Simple. I over-thought mine when I did it and was done in under an hour thinking I must have missed something. Nope, real easy.
Old May 18, 2011 | 01:40 PM
HeHateMe's Avatar
HeHateMe
I am not a mechanic, but I am going to install all my stuff myself. I bought it, so if I screw something up, oh well. Thanks for the advise again.
Old May 18, 2011 | 05:06 PM
HeHateMe's Avatar
HeHateMe
I went and bought the SE gaskets, and picked up a SE Air Cleaner Kit. We'll see how it goes.
Old May 18, 2011 | 05:31 PM
TheTroupe's Avatar
TheTroupe
Run it with the stock air cleaner first.
Then install the SE AC Kit and I believe you will notice that will be running way to lean.
You will need to either have the dealer flash the stock ECU with a Stage 1 program, or install and SE ECU (not a great idea) or install a programmable 3rd part system.
I am sure other will chime in on this.
