How the hell....
Old Jan 12, 2012 | 09:38 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
It comes apart, at least the bulb comes out of the back. You have to peel the gray glue off the black rubber where the wires go into the back.
Drew
Old Jan 13, 2012 | 04:24 PM
tbonetony06's Avatar
tbonetony06
Autozone sells a lens restoration kit that works great! I had to use it on my daughters car, you could barely see at night and now they look brand new. I was also told to wax the lens when done to keep it from happening again. I don't know if that is true or not but I waxed them and they are still crystal clear going on a year now too.
Old Jan 13, 2012 | 04:34 PM
SIDECAR BOB's Avatar
SIDECAR BOB
thinking he means the foggy hazy smoke stuff inside the light, not the outside of the lens, heard the alcohol trick works pretty well
Old Mar 4, 2012 | 03:22 AM
CrazyHorse23's Avatar
CrazyHorse23
3rd Gear
Have the same problem on a new Road King Classic. I removed the bulb, sprayed some "Invisble Glass" cleaner inside, placed cotton ***** inside, and moved them around the leans and reflecter with a long qtip (any skinny stick that won't scratch the glass will work). Then I pulled those out with needle nose pliers, and put 4 more in to remove most of the cleaner. Finshed it off with a hair dryer, and checked them with a flashlight. They were spotless.
HAG11Limited
Mar 29, 2013 11:34 PM
russl179
Oct 28, 2010 08:20 PM
Bill03E
Apr 7, 2008 09:27 PM
Toytech
Apr 7, 2006 10:09 AM
solisimo1
Feb 4, 2006 11:45 PM
