How the hell....
Old May 22, 2011 | 08:14 AM
YammyDrummer's Avatar
YammyDrummer
Default How the hell....
Do you get the lense off the passing lights?
My passing light lenses are all hazy, foggy, dirty, something (???) on the inside. So I took them apart to clean, but can't get the lense out of the housing. What am I doing wrong??? Wouldn't have thought this would be that hard of a trick, but it's got me stumped! Any suggestions?
Thanks in advance.
Old May 22, 2011 | 08:24 AM
ghostrider69's Avatar
ghostrider69
I didn't think you could take the lense off. Mine looks like the lense and bulb housing are glued together.
Old May 22, 2011 | 08:30 AM
Tracker56's Avatar
Tracker56
I do believe they're sealed beam lamps. At least the ones I have are...
Old May 22, 2011 | 08:32 AM
YammyDrummer
That's what I was starting to wonder, but couldn't see any glue or other indication they WILL NOT separate. Just thought I was doing it wrong . But if that's the case, any suggestions on how to get rid of the haze?
Old May 22, 2011 | 08:57 AM
Bad Daddy's Avatar
Bad Daddy
I took some Stoner Invisible Glass and sprayed it inside the housing. then swirled it around, let it sit, and then rinsed in hot water. Done.
I've been told that washing them in the dishwasher works, but haven't tried it to verify.
Old May 22, 2011 | 09:58 AM
RANGER73's Avatar
RANGER73
If it's a sealed beam, it doesn't come apart. They make an acrylic head light lens polish you could try. You can probably get it at your local auto parts store.
Old Jan 12, 2012 | 06:05 PM
CorknBean's Avatar
CorknBean
Default Easy Dirty Lens Fix
I have a '07 Road King. I took the light apart per the Shop Manual directions to disassemble the light and replace the bulb.
After removing the the bulb I put a few drops (3-4) of isopropyl rubbing alcohol inside the lens. Swished it around a few seconds, then used my compressor to blow most of the alcohol out. It worked GREAT!
Old Jan 12, 2012 | 08:43 PM
PanHeadRich's Avatar
PanHeadRich
Good to know. I need to do this to my headlight.
Old Jan 12, 2012 | 08:45 PM
pccoder's Avatar
pccoder
Those headlight restoration kits work fairly well. You've got to be patient and follow the instructions. Too much sanding and you can make it worse.
Old Jan 12, 2012 | 09:34 PM
Big H's Avatar
Big H
Everybody mentioned about not being able to get the lens off the housing (backing). That part is a given. Your question seemed to imply you cannot get the passing lamp itself out of the chrome housing. That would be a weird problem to have. Which is it?
