Detachable Component Fit??
Old May 23, 2011 | 03:06 PM
wiktor's Avatar
wiktor
Default Detachable Component Fit??
Hi All,
My 2011 Fatboy is the first bike I've bought with detachable components. It has the windshield and seatback with luggage rack. My question is how well should this stuff fit? I have to pull or push on the tabs while putting them on their docking points to put them on. My dealer said that I don't want things to fit loose or they will rattle. I'd just like things to fit right so you don't have to wrestle with them to put them on. Is this normal or should the dealer fit these better? Thanks!
Old May 23, 2011 | 03:12 PM
jed1069's Avatar
jed1069
I have an 09 Fatboy and my backrest I have to pull the tabs slightly apart when putting it on. It does not require much force at all.
Old May 23, 2011 | 03:22 PM
jbg's Avatar
jbg
if you don't have to pull a little, it's too loose. And you'd rather have them a little tight than loose. It sounds like they're on there correctly. It should take a good yank to get the windshield off. But it still only takes 5 seconds to remove.
Old May 23, 2011 | 08:52 PM
wiktor's Avatar
wiktor
Thanks for the replies! The windshield fit is worse. It comes off easy but you really need to push in on the top tabs (towards each other) to get it back on.
empirelloyd
May 11, 2014 01:50 PM
Harley1554
General Topics/Tech Tips
Jan 26, 2011 12:39 PM
0o0ow
Jul 18, 2007 07:20 PM
bfrmbama
Apr 15, 2007 11:24 PM
blown alcohol
Aug 21, 2006 05:32 PM
