Oil leak
Old May 24, 2011 | 01:48 PM
DC Mike's Avatar
DC Mike
From '99 to '04 the primary drain plug is an Allen wrench type with tapered threads.
From '05 on up the primary drain plug is a TORQ bit type with a small flange.
The '05 up uses an O-ring to seal the hole, replace the O-ring when you change the fluid. If it continues to leak, then it is most likely the main seal as stated above...
Mike
Old May 24, 2011 | 02:23 PM
cpiad's Avatar
cpiad
Account Closed
....new bikes have hex bolt. Come out with an Allen key.
Assuming bike has not been dropped on primary or wrecked...either one of each can deform that long casting.....then.... go to HD Dealer....buy o ring for primary plug and gaskets for the chain case and Derby. Be sure and install new gaskets correctly. Drain oil....install new o ring and gaskets. Fill case per manual....do not overfill. I use and recommend Redline Vtwin primary chain case oil over SUNOCO/HD one fits all synthetic.
Clean the engine, tyranny and case area with mineral oil and a few rags...now ride and look for leaks.
Old May 24, 2011 | 02:29 PM
cpiad's Avatar
cpiad
Account Closed
Originally Posted by poppavein
Redline oils can be red, Royal Purple can be purple. They are high quality oils.
Color does not last....we use florecent dye and a blacklight. The dye comes in tiny bottle ....you add according to direction...run the engine and trace the leak in dark garage and blacklight. I clean motor as best I can so I can see new oil trace better.
Old May 24, 2011 | 04:45 PM
jcallesano's Avatar
jcallesano
i get seepage from the top of my heads..... im starting to get really uncomfortable about it
Old May 25, 2011 | 07:38 AM
aces25's Avatar
aces25
My idea was to drain and fill the tranny first with Red Line to determine where the leak is coming from (trans or primary).
If I pull the outer primary cover off to replace gaskets, why not go ahead and replace seals as well? I'd hate to put all those new gaskets on there if they are no good when I have to disassemble again.
Any idea where to buy Red Line products online? No one locally carries it.
Regarding the drain plug, it is not a torx or socket hex, it is a cap hex with a flange (search Mcmaster-Carr for "hex head flange cap screw"). Can't remember what size socket it takes.
Old May 25, 2011 | 08:30 AM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Get Redline at summit racing. http://www.summitracing.com/
Drew
fatkidfrank
Oil Archive (no new posts)
Aug 9, 2012 03:05 PM
stbobshadow
Jun 27, 2012 01:45 PM
Streets of Fire
Oct 29, 2008 08:21 AM
oldroadie
EVO
16
Sep 15, 2008 11:14 AM
jnogreen
Oct 17, 2007 07:57 PM
