Help me figure out what the hell is on my rocker clutch
Old Jun 8, 2011 | 11:53 AM
Kadorja's Avatar
Kadorja
Default Help me figure out what the hell is on my rocker clutch
Alright so I got my pedal in and kind of mocked it up and I just wanted to clarify what is what on here.... either I have to places to hook up a clutch cable or one of these pieces is extra?
Alright first picture this is obviously the spring and pedal assembled. I had the spring sort of mocked up to where to loops at... I do know it goes to the hole straight under where the hook is at in the picture I just didnt hook it up.
Alright in this picture I have a rod on a pivot on the back of the pedal. Im assuming the rod that connects to the transmission goes to this point but in this next pic you will see why its confusing.
Alright on this last picture you will see this plate that bolts on that acts as a lever moving with the clutch pedal. In other pictures ive seen you can hook a clutch cable up to this lever instead of using the rod part.
Are all pedals built like this or is mine basically a universal pedal. It has a shitload of mounting holes in it which makes me think it is just universal and the fact it has linkage for what appears to be a left and right side clutch bike. Hopefully all I need is to figure out how to mount it and get a clutch cable that will work with the lever and route it properly. Or this pedal is garbage and wont work at all.
Josnj1
May 28, 2019 11:13 PM
Brooks2131
Sep 19, 2018 07:36 AM
osirisdean
Nov 2, 2011 12:10 PM
JakesDad1
Jan 31, 2011 10:26 AM
pitbull65
Mar 23, 2010 02:03 PM
