OK Guys,
I need a belt tension gauge for a 2011 Fatboy. The part number is HD-35381-A. It's different somehow from the common one in the HD catalog. Called two dealers to get one, one said it was a Kent-Moore tool and they don't have any but gave me the phone number. I called and they can't sell me one because it's a restricted HD part. Called the other dealer and they don't have any idea. Anyone have any idea on where I can buy one?
Grab the belt at the center between the two pulleys. Twist it. If it will twist to a 45 degree angle, it's perfect. 90 is too loose and 30 is too tight.
As cheap as this sounds, you'll be as accurate as using a gauge and you can use the money for a different specialty tool that you really need.
Did they say why it needs a special one? Just curious. I think I have a standard one in the garage That I was going to offer to give you until I saw that you said it won't work.
I had the same problem trying to find it using that number from the repair manual. The instruction sheet that came with mine as well as the receipt stat6e that it's 40006-85. I paid $29.95.
Ditto that. The belt tensioner gauge is a piece of junk...not worth two bits.
I'm going to use that tip. I just changed out my sprocket and rotor and need to get my butt back out in the garage and mount the thing.
