Could be the Fuel Pressure Regulator (FPR) ($29)
The FPR is a mechanical device located in the tank...when the fuel pressure starts to go too high...the FPR opens and re-routes fuel back into the tank...no codes...mine was sticking open occasionally.
As long as you are on the gas...the fuel pressure is fine...when you let off the gas...the fuel pressure rises.
Funny thing...this is a STOCK item at the dealerships...does this mean the FPR failure is common?
