PCV retrofit 07-08
Old Jun 11, 2011 | 11:36 PM
ssrgeoff's Avatar
ssrgeoff
Default PCV retrofit 07-08
Ordered from Fuelmoto a PCV for my bike which by the way took care of all the decel pop and the cherry red headers on my cholos. Question I have is the top left allen screw unfortunately will not come loose as the threaded collar broke loose and spins with the screw. It says to move it up and remove the EFI tray but I believe that to be on the 09+ models since if you remove this one your left with a hole in the fender. How are you guys mounting the EFI as my seat doesn't seem to currently sit properly. If I drill out that screw will that make all the difference?
Old Jul 26, 2011 | 06:53 PM
cmosentine's Avatar
cmosentine
Did you ever get the PC installed? I am having the same installation problem - where to put the ****.
Old Jul 27, 2011 | 12:28 PM
ssrgeoff's Avatar
ssrgeoff
I just responded to your other read... the short answer is no. I was able to get all the bolts out and move the ECM but because the tray is only so big it didnt matter if the ECM is sideways or not... there simply is not enough room. Luckily the Badlander seat is a little less forgiving than stock so it sits ontop of the pigtail, still not a proper sit but I havent had much free time to really get into it... I may dremel out a bit of the seat.
fattyboyy
Jul 22, 2012 03:15 PM
FAUVDOG
Mar 13, 2011 08:59 AM
FAUVDOG
Mar 10, 2011 07:36 PM
trapper_canada
Jun 30, 2010 09:39 PM
FLoTR
Feb 21, 2009 07:49 AM
