PCV Installation
Old Feb 20, 2009 | 05:01 PM
FLoTR's Avatar
FLoTR
Question PCV Installation
I just read here that FuelMoto will sell me a pre-programmed PC V for my configuration for around $300.00. Does that mean that all I would have to do is install the box and route the wires on my '09? How much, and what, is involved in the installation? And for those wondering why I'm asking another PC question here instead of searching the forum,,,,,, Sorry, but I did a search already and PC 3 was the best I found and they seemed hesitant at first to speak of details. Then when they finally spoke, it was not detailed at all. Thanks people.
Old Feb 20, 2009 | 05:13 PM
TexasSG's Avatar
TexasSG
If you have a phillips head screw driver you can do the job. My daughter could do it in about ten minutes.
Remove seat, unplug ecm, plug PCV into unplugged harness and ecm, attach PCV on top
of ecm with supplied velcro, tuck wires into area in front of the battery box, reinstall seat, enjoy.
Old Feb 20, 2009 | 05:21 PM
EGlideKid's Avatar
EGlideKid
Actually, I think it will come to $311 delivered and yes it will have the map they've built for your bike with your mods. You need to tell them everthing you've done to the engine, air, exhaust, etc.
Ask for Jamie or Keith and they will set you up with the best $300 product you could put on your bike.
As far as installation goes, mine took 45 min, and I was taking pictures for a thread on HDF. Do a search. there are a bunch of us that have gone on before you.
Old Feb 20, 2009 | 05:24 PM
FLoTR's Avatar
FLoTR
Are you $h!t!n me?! "That's Awesome Bill"!... My mind is made up. Life should always be so simple.
Old Feb 20, 2009 | 05:26 PM
TexasSG's Avatar
TexasSG
All true bro, best bang for the buck I've ever had! ...........ever.
Old Feb 20, 2009 | 05:31 PM
FLoTR's Avatar
FLoTR
I found your Thread. That's very helpful. Thanks.(I didn't search back far enough the 1st time I guess)
Old Feb 20, 2009 | 05:50 PM
EGlideKid's Avatar
EGlideKid
No prob, bro. Let us know how it all turns out.
You know where to go if you have questions!
Old Feb 20, 2009 | 06:25 PM
monkyman's Avatar
monkyman
I think you have to disconnect the O2 sensors and install jumpers on the harness as well, correct? I have one on the way as well.
Old Feb 20, 2009 | 07:12 PM
EGlideKid's Avatar
EGlideKid
If you have ANY doubts, call FM and talk to Jamie. He is down to earth and doesn't treat any question as dumb.
Wish I could help, but the '07 install is different to a degree. Your '09 install's will be different, depending on whether you are installing the AutoTune module. If you check out my install thread, I think the '09 pretty much mimics that unless you put the AT on as well.
Maybe Jamie or iclick will come on-line and give us a clue in the meantime.
Old Feb 20, 2009 | 07:25 PM
FLoTR's Avatar
FLoTR
You guys are SOOOO helpful. I'm not in a position to do anything right now, which gives me ample time to get the right chit together while I get my ducks lined up in a nice little row.(they have to be just right you know)
