Nucklebusters
Old Jun 15, 2011 | 10:38 PM
barto1's Avatar
barto1
Default Nucklebusters
OK, just learned the hard way how not to change your mufflers! evidently my 3/8 wrench was a wee bit too small and the bolts were a wee bit too tight. Bleed like a stuck pig, old mufflers still on, hope I didn't strip the bolt heads. It's off to the parts store tomorrow to get a longer 3/8 wrench.
Old Jun 15, 2011 | 10:47 PM
BassCatcher's Avatar
BassCatcher
Bikes are knuckle busters, no doubt about it. Got so tired of walking back into the house I now just keep the band aids right in the garage.
Old Jun 15, 2011 | 10:59 PM
barto1's Avatar
barto1
wife walked in and saw the blood and asked if I needed to go to the hospital. Said no, auto parts store for better wrenches.
Old Jun 16, 2011 | 06:47 AM
JakesDad1's Avatar
JakesDad1
Hell...... I keep an entire first aid kit handy. Need it constantly!
Old Jun 16, 2011 | 07:03 AM
F117ewo's Avatar
F117ewo
A six sided socket will probably work better than any open or closed end wrench. It has much less of a tendency to slip and cause injury to you or damage to the bike or fastener.
Jake
Old Jun 16, 2011 | 08:09 AM
CJinNH's Avatar
CJinNH
When I first yanked the stock exhaust off my bike I soon discovered how sharp the cooling fins were. I didn't bang my knuckles, but did a nice job of shaving a bit of skin off removing the rear clamp... Didn't feel much pain, but bled pretty well.
Old Jun 16, 2011 | 08:17 AM
OldCoddger's Avatar
OldCoddger
Bart, I took the stock mufflers off and then put the Screaming Eagle on. Those six bolts that have the 3/8 head are a PITA. When you put them back one muffler will go on easy as you can get to them. The second one is where the problem is, trying to get the last two bolts (top muffler) started. BTW a good 3/8 rachet wrench is worth the price. Good luck if you are putting slip-on back.
Old Jun 16, 2011 | 11:21 AM
Misbehaven's Avatar
Misbehaven
Save the skin wear some Mechanix Wear gloves. They are great.
Old Jun 16, 2011 | 07:17 PM
barto1's Avatar
barto1
Yep, found the flexible ratcheting wrench's. Worked great on the two that were not as striped. The other two in the hardest spots I used a socket set that is designed for the bolts that get rounded. Worked better. Only took an hour with swivel head and lots of cussing. Getting the old ones off was easy, they slid right off, I only have 5000 miles on it so no rust. Added a bit of gasket sealant and put the new ones on. Test drive and man it sounds great, not too loud, but like a Harley! I may need to torque the top down a bit more though. How do you tell if the exhaust is leaking around the seal?
fugno
Apr 21, 2018 02:25 AM
kryingame
Mar 21, 2018 05:22 PM
cardboard
Apr 5, 2011 05:55 AM
TeachersOnHarleys
Feb 15, 2010 05:23 PM
sws1
May 12, 2006 12:26 PM
