Snap-On Torque Adapter
Old Nov 3, 2006 | 08:48 PM
ut_vols_fan's Avatar
ut_vols_fan
Default Snap-On Torque Adapter
I just finished putting the engine chrome kit on the bottom end of my bike and am getting ready to put the chrome rocker suport plates and rocker covers. Since I am not taking the engine out for this, the manual specifies using 2 snap-on torque adapters (7/16" and 1/2") on a few of the bolts that a regular torque wrench can't get to because of the frame. They look like the attached pic.
Snap-on wants $26 each or $130 for a set. Anyone know of a cheaper source or a GOOD workaround?
I usually but new tools when I need them, but don't see arecurring need for this one.....
[IMG]local://upfiles/17964/67AE297FE6F44F7C9B77DEF46F31B52E.jpg[/IMG]
Old Nov 4, 2006 | 01:00 AM
skips69's Avatar
skips69
Default RE: Snap-On Torque Adapter
I had my tank off when I addd the chrome engine kit to my 05' Standard (and was doing bars/internal wiring at the same time). I torqued the ones that I could get to w/ a regular torque wrench, then snugged them just a little more w/ a combination wrench or allen (can't remember which). Using these as an example, I "torqued" the odds ones with just the wrench by feel. Just initially torque in the middle of the range, and a little more with the wrench won't snap them. Worked for me - no leaks or problems...........
Old Nov 4, 2006 | 01:21 AM
billvaughn's Avatar
billvaughn
I agree with the above...Get a feel for the ones you have access then do the other ones...Just don't get greedy.....
[IMG]local://upfiles/2670/CEFFBEFC84354F61928032D6F22204DF.jpg[/IMG]
Old Nov 4, 2006 | 01:22 AM
20NightTrain03's Avatar
20NightTrain03
crows feet maybe? wouldnt be exact but close
Old Nov 4, 2006 | 11:30 AM
skips69's Avatar
skips69
No, if I remember correctly, not enough room to get a wrench on them - had to come from above with a short allen, or socket. I have combination wrenches that are open end and socket end - might have used one of those. I just remember it was only impossible to get to 1, maybe 2 bolts with the tank off, and I wasn't paying $37 for the adapter off of our Snap-On truck at work (to probably only use 1 time in my life). As a matter of fact, I think I even asked one of the tech's at the local dealer about this, and this was his recommendation to me That's what they do apparently (too cheap to use the correct tool also).
Old Nov 4, 2006 | 05:29 PM
monkyman's Avatar
monkyman
I got mine from http://www.mcmaster.com/
Type in Torque adapters
Where it says "Chose from 3 pages" pick "Locking Pliers, Sockets & Crowfoot Wrenches "
They are about half way down the page. About 12.00 for the sizes you will need.
Streetbobber75
Jan 13, 2019 10:26 AM
lloydrtr
Nov 1, 2011 08:13 AM
ut_vols_fan
Nov 6, 2006 12:43 PM
ut_vols_fan
Nov 4, 2006 04:35 AM
dawg
Nov 1, 2006 01:54 PM
