Attempting to get some tools together for current and future use. I know I need a 1/2" and a 7/16" 12 point torque adaptors for working on the rocker boxes and such. Are there any other torque adaptors needed for other parts of the scoot? Thanks.
The torque adapters are used to torque bolts in the rocker box. They have a 3/8 drive on one end and are 12 point on the other. They are a specific length so you can use a torque wrench to tighten bolts.
I used a 3/8 the other day. Don't forget to recalc your torque for the added length of the adaptor. The additional length of the torque adaptor can make a big difference in the amount of torque applied at the fastener.
- Torque adapter for the rear wheel bolts. I believe the bolt is 1 1/2". The adapter lets you put a torque wrench to it without dropping the exhaust. You won't get a 1 1/2" socket and torque wrench on that nut without it.
- A set of Oetiker pliers to re-clamp hose clamps ($19.00 on eBay)
- The HD Oil Filter wrench is cheap and works great
