Progressive drop in springs
Old Jun 23, 2011 | 06:21 PM
Roberto o8 Deluxe's Avatar
Roberto o8 Deluxe
Default Progressive drop in springs
Sometime back i bought the progressive drop in springs #10-2003 for my 08 Deluxe. Going with the Shotgun shock air in back and now going to install the front. The directions state to cut the pvc spacer to 3". How much will this lower the front ? the directions also state to remove front wheel and forks ? Why would that need to be done ? Maybe necessary for diff. model ? Anyway, Thanks for any advise.
Old Jun 23, 2011 | 06:28 PM
Malingerer's Avatar
Malingerer
Cutting the spacer to 3 " will give you the full 2" drop.If you can swing it while you are in the front end.I recommend the Ricor Intiminators.I found them to make a big difference.Especially on a lower bike.
Old Jun 23, 2011 | 06:36 PM
Roberto o8 Deluxe
Just checked them out sound great, will do. Thanks for the help bro.
Old Jun 23, 2011 | 08:08 PM
TheTroupe's Avatar
TheTroupe
If you can't swing the Ricor Intiminators, then just increase the fork oil to HD heavy (not super heavy) and you will be ok. The pre-load space at 3 inches is the way to go but it is not what only determines the drop it is the short springs.
Old Jun 23, 2011 | 08:18 PM
SMF's Avatar
SMF
What malinger said
jeemann99
Mar 24, 2015 01:20 PM
evodub1960
Jun 23, 2010 08:31 PM
evo1340
Jan 27, 2010 10:19 AM
Kbore
Aug 8, 2009 08:58 AM
Low E
Feb 16, 2009 05:13 PM
